LT1 needs head gaskets replaced
Old May 27, 2005 | 09:11 PM
  #16
wolfepack95's Avatar
Unhappy Re: LT1 needs head gaskets replaced
it started with just loosing a little water . I checked everything from heater core to water pump and radiator cap. it just keep getting worse then finally it must of blew and it overheated. before i could get to a safe place the valves started to rattle so im hoping the head didn't crack...
Also i know what pimped out means by while your at it.. But i'm going to leave it stock and see how many more miles i can get out it before i go any deeper.. I have a 68 camaro that i realy want to build. But i love the way this 95 z28 runs and drives. So this is my everyday car.
Thanks again for all the input .. I feel more confident about tackling this job..
Old Sep 1, 2005 | 06:50 PM
  #17
Im finally and slowly taking the heads off my LT1. what is the best way to deal with the feul rail . remove the lines and leave it on the intake or remove it from the intake and swing it out of the way or remove it altogether??
Thanks in advance
Old Sep 1, 2005 | 06:57 PM
  #18
94zgreenmachine's Avatar
Originally Posted by 96_pimped_out
If you hang around this board too long, you'll find that replacing head gaskets actually costs around $6,000. Why? Because you'll get talked into porting the heads, swapping the cam, upgrading injectors, putting on headers, etc..
...all in the name of, "while you're at it"...
you sound like a "victim" also....
Old Sep 13, 2005 | 04:48 AM
  #19
unTAmedLS1's Avatar
Lt1 head bolts should be replaced but i dont think they are torque to yield like the ls1s are
Old Sep 13, 2005 | 10:58 AM
  #20
sssalah's Avatar
Thanks in advance
Yeah, if you have that disconnect tool just remove the 2 lines and take it out with the intake as a unit.
Old Sep 13, 2005 | 11:05 AM
  #21
sssalah's Avatar
96-97 LT1's used torque to yield head bolts from the factory.
Old Oct 14, 2005 | 07:51 PM
  #22
well i finally got my z back together.So far it sounds pretty good. One thing i forgot though was my power sterring gets hard at times. how can i tell if its the pump or the rack.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
