LT1 M6 Conversion: ECM Question
Can you use the stock A4 computer with a custom chip, or will I have to get a M6 computer? Also, is there a difference between the years ( '94 Z28 A4 is what I have ), and where is a good place to start looking? Thanks.
stickshift is right. The A4 computer will work fine. I am still running mine and haven't even reprogrammed it yet. It will throw a TCC code, but who cares. It doesn't affect the drivability of it, so no big deal. You can reprogram the A4 computer with a t56 program, which is optimal for getting the speedo right. I haven't used the speedo in years, so it hasn't bothered me. Then again, I don't have a clutch switch, reverse lights, or reverse lockout. The only one that bothers me is the reverse lights. Too lazy to fix right now though. Anywho, good luck with the swap!
Some moderator want to move this?
Also, your speedo is way off. You can probably get an M6 flash fromt the dealership.
