LT1 heads and guideplates
Sure you can.... no machining required.
Personally, I like the Isky adjustables because of the adjustability (duh).
Flatlander Racing and others carry them.
edit for url: http://www.flatlanderracing.com/index.html
-Mindgame
-Mindgame
Running guideplates and non self-aligning rockers is the best way to go for valvetrain stability. The closer to the center (length wise) you can support the pushrod the better for keeping the pushrod flex down. Think about it.
HTH
-Mindgame
HTH
-Mindgame
what rockers are you using? Im just afraid that the hex on the stud will hit the rocker. this is a budget daily driver, so whats a good suggestion. Again, thank you for the help. Prorac1
Pro,
I run a slightly different head than stock, which requires a shaft rocker setup. So what I'm running doesn't count.
The Comp Pro Magnums (chromoly steel) are a great buy. Crower makes a stainless rocker that's similiar but cost a bit more..... same for the stainless Comp Hi Tech.
Alot of guys on the board also like the Crane golds and I'm also partial to Harland Sharp's aluminum rockers. Any of these would serve you well, so just find a good price and go. As for nut to rocker clearance.... never seen a problem there. Watch for retainer to guide seal, rocker to retainer and coil bind.
HTH
-Mindgame
HTH
-Mindgame
oldschool
Feb 9, 2016 09:21 PM
