LT1 M6 1 7/8 header?
Old Jan 27, 2009 | 09:57 AM
DR.ZED's Avatar
Any options for non-stepped full 1 7/8 headers for an LT1 M6?
Old Jan 27, 2009 | 10:01 AM
sn8ke eatr's Avatar
be prepared to give up a little low end. and unless you have an all out build a 1 3/4 longtube like pacestter ,jethot, hooker, etc will work just fine.
now if you have an afr 396 with a blower.. well then ok.
i have a 383 making about 425 wheel then a 125 shot. i use longtube pacetters. i think they suck because they looked like **** within 500 miles of driving but as for the power they do just fine. next time around ill do kooks or lpp
Old Jan 27, 2009 | 10:04 AM
DR.ZED's Avatar
For sure. Its a 383 with a huge blower.
Do you know who sells them?
Old Jan 27, 2009 | 10:18 AM
cnorton's Avatar
You'll probably need to have that header custom made. I've never seen that configuration available off the shelf.
c
Old Jan 27, 2009 | 10:40 AM
Nostang 96z's Avatar
Hedman headers makes a great full 1 7/8" header for Lt1's. You will need to have the adapter plates for exhaust port matched to your heads in order to work as they are a stahl flange. These are ~$770 from summit racing. I would compare the quality to Kooks except the hedman's are not stainless.
Old Jan 27, 2009 | 06:07 PM
Kooks makes a 1-3/4" --> 1-7/8" step header for the LT1 F-Body. K6400-2RHS. Close to $1,100.
Old Jan 28, 2009 | 11:08 AM
95 Civic's Avatar
I have a set of Hooker 1-7/8 on my cam only car and had them on my bolt on on car and had no issue.. I love em..
Jason Short
Jan 19, 2015 06:34 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
Jul 4, 2005 05:00 PM
NJ SPEEDER
Jul 19, 2002 10:22 PM
