LT1 to L99 4.3l v8
Old Feb 27, 2012 | 02:29 AM
andssrew1990's Avatar
LT1 to L99 4.3l v8
Just wondering what is all needed to replace a LT1 with a l99 4.3l V8 out of a caprice.
LT1 is in a 1994 firebird but engine is blown and needs rebuild. Have a L99 that I can get extremely cheap and low mileage from a 1994 caprice.
I understand the l99 is physically the same size as a lt1, and it being the same year as my firebird, it should not be a difficult swap. Wiring should be the same and all I need to do is swap the ECU to the caprice ecu.
I am not concerned about loss performance. I purchased the car with the blown engine cheap and just want it as a daily driver. I owned a 3.4l camaro before and was happy with its performance. I assume the 4.3l is a tad better than a 3.8l. Anything is better than my current 91 escort...
Old Feb 27, 2012 | 05:05 AM
Guest47904's Avatar
Guest
Re: LT1 to L99 4.3l v8
This post is better off in the V6 forum.
Old Feb 27, 2012 | 05:12 AM
May I ask why? Both are V8 engines that fall in the same line of engines?
Old Feb 27, 2012 | 06:45 AM
I don't think you would need anything special for the swap. It's a smaller displacement version of the LT1 and not a V6.
Old Feb 27, 2012 | 02:04 PM
96capricemgr's Avatar
The 94 Caprice engine will have a vented opti so you might need to adapt the wiring for that but that is an UPGRADE from the unvented opti on a 94 f-body.
You would need to swap the damper hub because the accessory drive depth is different. The b-body got 2 knock sensors, I believe your car only got one so one wont get plugged in.
The L99 has 19lbs injectors just more an FYI than anything. I would NOT try swapping the pcm. I am sure you could get someone to put together an L99 tune for an f-body and then your speedo will be right and everything which it wont be with the Caprice programming. The pcm itself is the same PN.
One thing I am not really sure about is the clearance between the straight plugs and your exhaust be it manifolds or headers, easy enough to test on the engine stand.
I hope that all does not sound like a big deal, it is all minor.
When I bought my 96 it had a L99 in it and it was replacing a 84 with a 305. The 96 is a much heavier car despite the same chassis. As such it felt down on torque compared to the 84 with a 305 BUT it was also clearly up on HP. I think it would be better than the V6.
Old Feb 27, 2012 | 10:52 PM
Ok, well I just bought the l99 with 70K miles with the PCM for $200. $700 cheaper than a lt1 in my area.
The engine was pulled from a car with a 2.73 gear ratio, same as mine.
The engine also included everything from oil pan up to intake and fuel rail. Also has the exhaust manifolds.
Now I contacted a tuner in Elgin IL and he said he could tune a pcm for this setup, but if I have the l99 PCM with the l99 injectors, and my car has a 4l60e with the same rear gear ratio, wouldnt the stock tune work?
So all I got to do is change the damper hub which I have on my current LT1.
Old Feb 28, 2012 | 09:36 AM
I really don't think the b-body exhaust manifolds will connect to your f-body exhaust.
2.73 would be an odd ratio in a b-body, only ever heard of one before, generally a civilian L99 car was 2.93 and the cop car was 3.23.
I also believe that even if the gearing was the same you still have tire size issues and I thought there was an AC difference in the pcm as well. I would have Ion do a program for you. I have had him repair a pcm and installed his programming in friend's cars and it all went well.
Old Feb 28, 2012 | 06:21 PM
96z28_lt1's Avatar
also the l99 injectors seem to be 19 an hour from what everyone is saying and i believe lt1 injectors are 24lb an hour so i suggest swapping injectors from the lt1 over, for the tune on lt1 computer won't match the l99 engine set up
Old Feb 28, 2012 | 08:15 PM
Well I got the old LT1 and trans out today. Took it out the top and only took a bit under 2 hours. Will have the LT1 and L99 side by side tomorrow.
Im going to double check on the rear ratio, but could of sworn it was 2.73.
I will be using the Fuel rail and Injectors from the 4.3l l99 with the l99 computer.
And on the exhaust, it was already cut so I am having all new piping welded in at a shop.
See how well that does, if the stock tune cant do it, Ill just send in the extra pcm laying around to get programmed.
Hot Rod Hawk
Aug 30, 2002 10:12 PM
91 Redd Sledd
Aug 11, 2002 01:25 AM
91 Redd Sledd
Aug 4, 2002 10:47 PM
91 Redd Sledd
Aug 4, 2002 04:28 PM
91 Redd Sledd
Aug 3, 2002 11:50 AM
