Lt1 intake porting
Old Dec 14, 2005 | 12:59 AM
scottslt1z28's Avatar
Lt1 intake porting
I am thinking of buying this off of someone i know to dress up my engine bay a little bit and also to allow my LT to breath a little better because its ported
HOWEVER, my question is what do you guys think of this port job????
it doesnt look like the cleanest in the world.....would i want to have a shop make them perfect before i installed them or would it be ok to just throw it on??
Also im not really trying to do this for a performance upgrade, but more of a engine bay dress up thing.........however since it is ported would i gain much hp from it??
THanks guys, Scott
Old Dec 14, 2005 | 04:25 AM
RE AND CHERYL's Avatar
Re: Lt1 intake porting
Porting the intake manifold really gains you nothing. I discussed it with Loyd Elliot and he said it would add about 5hp to the port job on the heads. Not sure it would add anything if the heads were not ported to match.
I can't really see any port work in your pics. The runners look normal to me. Did they port it for a bigger throttle body?
I've got one just like it. I even polished the top ribs and fuel pressure rails.
Old Dec 14, 2005 | 06:58 AM
curly's Avatar
Looks like they just ported for an aftermarket TB..... looks like a good job though. Grab it if the price is right and you have an aftermarket TB you want to run. I gasket matched my intake with the good 'ole dremel.
Old Dec 14, 2005 | 09:33 AM
Mean Green's Avatar
looks decent enough if the price is good. a little bit of patience and a dremel tool and you can clean that up a bit yourself.
Old Dec 14, 2005 | 01:56 PM
i just wanted it to dress up my engine bay a little.
What tool do you guys use on the dremel to port them???
Old Dec 14, 2005 | 06:06 PM
curly's Avatar
They have a conical bit/cutter made for aluminum.... that's what I used. Just don't push it too fast when you're cutting or it will heat up and "load up" the cutter. I ended up having to buy a second bit after I did this to the first one.
Old Dec 14, 2005 | 06:13 PM
turbo_Z's Avatar
If the runners have been ported then they could potentially rob some power because of an overlapping problem. You never want the intake runners of an intake to be larger than that of the runners on the heads.
Old Dec 14, 2005 | 06:22 PM
The Engineer's Avatar
The red color indicates the mainfold is actually an LT4, and not an LT1. Although, it could be an LT1 that has been painted red. But it appears to me to be an LT4 when you look at the bolt holes, which have the bare aluminum which is exactly how the red LT4s are powder coated.
If it is and LT4 intake, the intake ports will not match the LT1 heads correctly. It also appears to have the TB venturas machined out to 58mm.
Old Dec 14, 2005 | 06:37 PM
DiabloGT's Avatar
how much are you paying for it? because im in need of an lt4 intake if this is one
Old Dec 14, 2005 | 07:04 PM
93zted's Avatar
Great photos of the inside of the manifold. It does look like a LT4 manifold though.
Old Dec 14, 2005 | 08:54 PM
hmmm, the guy said it was a lt1. And he just powdercoated it. he wants $75 plus my stock intake. Personally i dont think its worth that much, maybe 75 without my stock one, but thats just My opinion
Old Dec 14, 2005 | 09:43 PM
turbo_Z's Avatar
Sounds reasonable to me based on what Ive seen powedercoated LT1 intakes go for in the past... plus its modified to accept a 58mm TB.
Old Dec 14, 2005 | 09:47 PM
so are you guys saying this in a lt4 intake? wtf, i am guessing the guy doesnt know what hes talkin about then
Old Dec 14, 2005 | 10:09 PM
turbo_Z's Avatar
Im sure its an probably an LT1 intake but powdercoated to look like an LT4. They are pretty common... red intakes looks great.
Old Dec 14, 2005 | 10:29 PM
sbs's Avatar
sbs
The shade of red, the amount of sheen, the clear areas around the bolt holes and the overspray look nothing like an LT4 intake.
It's a red LT1.
