CamaroZ28.Com Message Board
-   -   LT1 Intake Manifold Question (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/lt1-intake-manifold-question-885856/)
97rebuiltZ28 Jul 27, 2017 01:01 PM
How hot should the intake manifold of a 97 Camaro Z/28 be? My Camaro intake gets hot enough to be hot to the touch, and you can't hold your hand on it for more than few seconds. The reason I ask is because I know that the LS1 has a nylon/plastic type intake cover and it only gets slightly warm, but I don't know how hot the LT1 should be even though it's metal.
shoebox Jul 27, 2017 02:20 PM
Re: LT1 Intake Manifold Question
You really shouldn't be concerned with putting your hand on a hot engine. :) The LT1 is designed to run well past 200 degrees. Since it has a metal intake, it's gonna be hot.
97rebuiltZ28 Jul 27, 2017 02:22 PM
Thank you for the answer! That's what I was hoping to hear but I was just making sure.
Injuneer Jul 31, 2017 11:04 AM
Two things to consider, if it's "really hot"......
- is the heat shield still on the bottom of the intake manifold? There's a sheet metal cover that keeps hot oil off the bottom of the manifold.
- have you done the throttle body coolant bypass? Removes the hot coolant from the throttle body, minimizing heat transfer to the intake manifold from the coolant. Picks up free 6 HP at the same time.
97rebuiltZ28 Aug 1, 2017 10:08 AM
I assume the Intake Shield is still on because we put the manifold back on exactly how it came off of the old engine. I have not done a throttle body coolant bypass.
Injuneer Aug 1, 2017 03:34 PM
Courtesy of Shoebox:
http://shbox.com/1/tb_bypass.jpg
Dyno test:
Modifications #8
