LT1 Intake on a 3rd gen...
Old Oct 27, 2005 | 10:43 PM
IrocManiac's Avatar
So guys I've been reading evidently the LT1 intake can be used on a TPI car? Anyone have an article or link or info on this? I'd like to know what needs to be done how hard it is, how long it takes etc. I tried to google it and got nothing good
Old Oct 27, 2005 | 10:44 PM
Mean Green's Avatar
Re: LT1 Intake on a 3rd gen...
i'd love to see how your coolant passes from one head to another and where the Tstat is going to go.
Old Oct 27, 2005 | 10:56 PM
knta4dnu's Avatar
Try this http://lt1intake.com/
Old Oct 28, 2005 | 09:15 AM
IrocManiac's Avatar
I wonder how much of that HP difference on the L98 was due to the came change and how much to the LT1 intake. I would assume a lot of it was due to the intake especially the major shift in where the power is. The TPI setup is great at building torque but quite anemic above 4500rpm.
Old Oct 28, 2005 | 09:30 AM
1BadBrd's Avatar
doing this to my friends car as we speak. It will take 2 weeks to receive the kit but it costs around $700 for it all. I will report back what happens.
Old Oct 28, 2005 | 09:38 AM
KrazedZ's Avatar
For the money, your best bet is to go for the Holley Stealth ram intake setup.
Last time i've looked at it, it was like $275 for the intake setup and another $150 for fuel rails. If its $700 for a kit to install a LT1 intake on standard 23 deg heads, i think thats way too much.
Old Oct 28, 2005 | 09:49 AM
IrocManiac's Avatar
Yeah so do I, that website had it listed for 400 bucks but then they had a bunch of other **** listed which I guess may be required. If thats the case then yeah there's better options. 275 for the stealth ram setup? Thats cheap, when I had my 3rd gen it was like 600 bucks
Old Oct 28, 2005 | 10:13 AM
KrazedZ's Avatar
Just checked, summit sells them for $299.95,,,they might be cheaper if you look around, fuel rails are optional, you can get away with using your stock tpi rails.
Old Oct 28, 2005 | 10:32 AM
Dave89IROC's Avatar
where you getting your info?
Old Oct 28, 2005 | 11:07 AM
KrazedZ's Avatar
Holley claims that you can utilize your stock TPI rails, from what was told to me by them. I used a set of LT1’s and modified them a bit and they worked fine.
Old Oct 28, 2005 | 02:00 PM
1BadBrd's Avatar
i know it sounds like a lot and it is, but a friend tried the sealth ram on his 383 and it was junk. His dyno session proved it compared to the LT1 intake. Just the different intake and injectors made a huge difference on his dyno session, don't know he #'s off hand, but he saved alot of money cause he had the knoledge and resorces to convert the intake on hos own. I think the increased air flow was better but increased fuel delivery was the other half that made the difference. I know the price is shocking, and if it were my ride i would do the work myself, but he is on a time schedule and just wants it done, so.... Check out LT1intake.com, the prices must have changed since more people want it.
onefastgta
Mar 19, 2015 10:10 AM
formula218
Dec 2, 2014 04:27 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
Nostang 96z
Sep 10, 2002 08:54 PM
