Lt1 hotcam Question
Hello,
I could not find an exact answer to my question so sorry if it sounds like a repeat. I can get access to a hotcam at a great price. I also found a shop that would install it at a fair price. I wanted to know that if I upgraded the springs, could I run the hotcam with the stock lt1 rockers? The price the shop quoted me will not always be that cheap, so I would like to take advantage of it while I can. I would possibly later upgrade to roller rockers. My car has longtube headers, and a cold air intake. Thank you for any help. |
Re: Lt1 hotcam Question
Also, are there any other small cams that would work well with the stock stall converter?
Originally Posted by huey.bankai
(Post 7001610)
Hello,
(Post 7001611)
You absolutely need new valve springs compatible with whatever cam you get and you will need a PCM tune so the car will run right and get the performance gain the cam is intended for 1.5 stock rockers will "work" but you will get more performance from the cam with 1:6 RR |
I'm running the LT4 HOTcam in a ZZ4 which is currently in my 89 stepside pickup now. I ran it with the 1.6 rockers while it was in my Chevelle, then took them out and went with stock rockers just for peace of mind with the truck. I couldn't tell any difference before and after. IMO, save your money. If you do upgrade later, it's just a matter of removing the valve covers, and isn't nearly involved as a cam swap..
Thank you for the help!
I am actually upgrading to the torqhead 24x system. My budget after all this is tight, but I can kill 2 birds with 1 stone by having them tune it for the cam in my base tune.
I have another question:
Someone locally is selling a set of 1.6 roller tips. Would this be better than the stocks? I found a good set of valve springs on summit others use. And also, since my car is a 94, doesn't it already have hardened pushrods? So hypothetically I could get guide-plates, springs(the ones I found work with the stock retainers and everything), and the 1.6 roller rocker? |
You're going to pay someone $$$ to install it for you, and you're wasting $$$ on the 24x system, but you want to nickel and dime the parts that might actually make your car go faster... If you're paying for labor don't dick around with trying to come up with your own bargain-basement collection of parts. Read some of the hundreds of old cam-only build threads on this and other LTx forums and choose a known-good combination of parts. |
Don't waste money on roller tipped rockers. The real benefit is in the roller trunion that full roller rockers have.
After searching I was able to obtain a cc502 cam, 1.5rrs, I purchased springs, pushrods, and guide plates. Also will get valve seals and do the timing chain too. Thank you all for all the help! Will keep you updated with the process.
