which lt1 head gasket??
putting P&P stockers back on and would like to raise the compression a tiny bit. what gaskets should i get? if anyone has a link to there thickness it would be great. thanks in advance.
if you want to raise the compression, use Impy SS gaskets
I was just gonna say exactly what Zack said. Impalla SS gaskets are thr right choice for what your looking for.
impy SS gaskets :thumb:
i ran them on a stock motor making close to 12:1 c/r with 150 shot of nitrous and they held up just fine ;) |
What about if you went to GM couldnt you get Impala SS heads gaskets? Would they be the same thinkiness as impy? (whatever that is)
ya the impy is an impalla ss for short. you can use the GM gasket made for the impy with no problem. the stock gasket is 39 when the impy's is 29. it will increase compression from 10-4 to 10-5 only. not much but why not do it with the heads off
thanks for the impalla ss tip. how about going with a copper gasket?? would that be thinner and give me another tenth on the static cr? i am guessing this is one place NOT to use something from a tube??
Originally posted by Red_94Formula it will increase compression from 10-4 to 10-5 only. not much but why not do it with the heads off http://www.smokemup.com/auto_math/compression_ratio.php |
what year impala gaskets would you ask for
1994-1996
Aren't the Impalla heads cast iron? And if so how do the Impalla gaskets hold up to the different metal expansion rates of Aluminum on one side of the gasket and cast iron on the other. Wouldn't the different expansion rates of aluminum and iron cause unwanted friction of the gaskets.
Just wondering. |
Aren't the Impalla heads cast iron? And if so how do the Impalla gaskets hold up to the different metal expansion rates of Aluminum on one side of the gasket and cast iron on the other. Wouldn't the different expansion rates of aluminum and iron cause unwanted friction of the gaskets. Is the benefit of incr. compression from Impy gaskets on a NA 380rwhp car worth the above risk (if there is one)??? |
FWIW...
Stock Compressed thickness = .049" Felpro 1074's Compressed thickness = .039" B-Body Compressed thickness = .029" |
why don't you mill the heads down?
Originally posted by 95RagtopTA I'm also in the middle of preparing for a head/cam swap. I was originally planning on Impy gaskets, but after reading several posts discussing the above concern I'm leaning toward Felpro. Is the benefit of incr. compression from Impy gaskets on a NA 380rwhp car worth the above risk (if there is one)??? So to answer your question, yes it is worth it IMHO. Mike |
