LT1 to Gen I Dyno numbers...
Well I got my tune updated for my new injectors by MadZ28 (Ion) and put it back on the dyno. Before the tune I put down 322rwhp and 316 rwtq. This time with the tune I put down 338rwhp and 325rwtq. This is on a Land & Sea dyno, reads a lot like a mustang dyno. The guys there said multiply my numbers by 1.13 and that would be about my dyno jet #'s, so about 382/367 if thats right. Not real happy with the # was expecting more out of it. Here's the dyno sheet and graph. What do you guys think?
Specs: 355 C.I. LT1 to Gen I Conv.
Hyd roller LT1 Regrind 561/573 lift, 230/236 Cam, 1.65 Roller Rockers, Patriot 195cc Port/polished Alum heads 2.02/1.60, 58mm TB, Weisco Forged Flat top Pistons, Balanced/blue printed, 36# SVO, MadZ28 tune, HOOKER Long tubes and 3" Catback, 4.56s...
Dyno Vid...
http://www.youtube.com/watch?v=FYjg9Aci2VU
Dyno Vid...
Right now it has a MadZ28 (Ion) mail order tune. I need to get it dyno tuned but I cant decide if I want to swap cams and get a custom grind cam or not. That may be another thing holding me back because of my regrind stock cam...
First, if you want dynojet numbers go find one. I don't like guessing between one type and the other.
Second if you are making 380 that isn't so bad. A bigger cam would widen the gap between hp and tq.
Today, regrinding may still be used, especially for odball engines, but it's probably not the norm. If I were a major cam company, I probably wouldn't want to regrind someone else's cam, even an OEM. I might regrind one of my own, however.
Personally, we are in the (other than camshaft) grinding business, and we'd much rather grind parts we produced than "OPS" (the People's Stuff).
References: Google is your friend.
[QUOTE=2000GTP]I'm curious, how much does it cost to have a stock cam reground and what are the advantages versus having a custom cam made or buying a shelf cam./[QUOTE]
It's not so much the cost, but the limitations that are put on you with a regrind. As OldSStroker said the case depth is going to be what limits you and even then re-case hardening it can only get you so far. Your problem will be the base circle size will get too small to put any lobe worth anything on there.
All in all it's much better bang for the buck to just start out with a new core when they are available.
Bret
