LT1 flywheel question
i am replacing the clutch and was woundering what you guys think of resurfacing the flywheel. herd somewhere you should just go out and buy a new one unless you really cant afford it. but buying one is recommended. is this true
Re: LT1 flywheel question
Buy a new one or resurface. If you read the clutch warranty, or a repair manual, they'll both tell you you need to have a smooth surface for the clutch to break in properly. Supposedly, if you get a decent amount taken off you may need to buy spacers that go between the crank and the flywheel to make up the difference.
oldschool
Feb 9, 2016 09:21 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Camaro90RS
Jul 23, 2002 07:57 AM
