LT1 Emissions Question
Old Oct 24, 2005 | 08:09 PM
1993Fast_Z's Avatar
i have a question regarding my emissions, the requirements in my area are that it has to be visually correct...i just bought a set of Hooker Super Comps, and the guy that had them welded the A.I.R holes shut, but the threads are still visible inside the tubes.....i was wondering if there was anyway that i could hook the A.I.R hose's up to the tubes and just un plug the smog pump..that pump isnt belt driven correct? if i am correct it is electric...would this mess with the EGR or mess up the way my engine runs in any way?
Old Oct 24, 2005 | 10:49 PM
Re: LT1 Emissions Question
You could install as much of the AIR system as you want. The AIR pump is electric. On the 93-95 engines, all you need to do is unplug the pump, and make sure the fuse in the circuit is good. The pump will not operate, and you will not get an SES light, or a code. Couldn't affect the way the engine runs..... AIR only operates for a couple minutes at startup. With your header connections already blocked, there's no way it could affect the EGR or anything else.
oldschool
Feb 9, 2016 09:21 PM
cmdeshon
Dec 27, 2014 10:06 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Queens94z28
Nov 20, 2014 06:03 PM
