Lt1 distributor
Old Jan 24, 2004 | 12:31 AM
lt1g3n's Avatar
Lt1 distributor
I have a block from a 96 camaro LT1, and i am going to use optispark , when i looked under the intake, theres a hole where a normal hei distributor would usually go , at least it seemed.. am i able to use a regular distributor ?? Or should i just stick with my Optispark - (ive yet to buy my opti)
Thanks.
Old Jan 24, 2004 | 12:51 AM
97WS6SCharged's Avatar
You can drill the manifold to accept a normal SBC distributor, but since the back of the motor sits beneath the firewall on an f body, it's best to stick with the Optispark.
Old Jan 24, 2004 | 01:30 AM
lt1g3n's Avatar
cool, thanks, yea ill do that, especially because my harness is for an optispark.
Old Jan 24, 2004 | 05:15 AM
dkeers's Avatar
If you plan on running the stock computer you need to keep the optispark. The PCM won't supply fuel unless it sees the low res pulse from the opti.
DirtyDaveW
Dec 1, 2016 05:37 PM
brentbrowning01
Dec 3, 2014 10:36 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
JoshWhite
Dec 15, 2001 04:21 PM
