LT1 Cruise rpm
Old Oct 24, 2006 | 10:11 AM
Mike.M's Avatar
LT1 Cruise rpm
Need a little help here deciding what overdrive gear would be better suited to the LT1,I have a completely stock 93 Vette motor w/39,000 miles it will have a cold air intake and long tube headers. This is going in an 68 Firebird with Tremec 5-speed and 3.42 gears with 26 in tall tires. I am trying to decide between the TKO 600 rr with an .82 OD that will give me a 2500rpm cruise speed at 70mph. or the TKO 600 with an .64 OD that will give me a 2000rpm cruise speed at 70mph. I guess the best way to describe what I want is to say that I don't want to have to downshift to make a pass at highway speeds and I plan to drive the car 2-3 days a week to work which is a 70 mile round trip. Any opinions would be appreciated. Thank you.
Mike
Old Oct 24, 2006 | 10:17 AM
jsetzer's Avatar
Re: LT1 Cruise rpm
Motor staying stock? If so I would take a cruise speed below 2k if I could. That being said all of my setups have cruised the smoothest around 2000.
Even now with my big cam the sweetspot is always right @ 2k no matter what gear it is in.
Since you are stuck with the 5 speed I guess that adds to the issue. With a t56 like all the 4th gens have you get 2 overdrives. Going from 1.0 to .64 is a pretty big jump for 1 shift.
I dont think you will have a problem "passing" with either gear, but .6 is pretty puny and it wont be a racecar in OD. Its been so long since I have had a stockish motor, but now I wouldn't think of passing without dropping at least 2 gears.
Sounds like fun, keep us updated.
Old Oct 24, 2006 | 10:33 AM
green.Z's Avatar
Re: LT1 Cruise rpm
Sounds like you will probably not be running a catalytic converter. In that case, that motor will be LOUD, at least with the regular series Flowmaster or equivalent. Depending on how much you like noise, I would vote for a cruise RPM of 2000 rather than 2500. You should still have plenty of torque for passing at 2000 and probably get better gas mileage as well.
Old Oct 24, 2006 | 02:24 PM
Mike.M's Avatar
Thanks for the opinions. I also called a few guys that are driving LT1 powered cars and they were in agreement with what the two of you had said so I ordered the TKO 600 street version with the .64 OD and the 2.87 first gear. I will probably be back asking questions as I move forward with getting the motor wired and ready to run. Thanks again for the help.
Mike
AdsoYo
May 2, 2018 03:21 AM
jayblev95
East South Central
Feb 15, 2015 02:26 PM
jayblev95
Jan 20, 2015 01:30 PM
jayblev95
Jan 6, 2015 11:52 AM
cmdeshon
Dec 27, 2014 10:06 AM
