lt1 cold issue
Old May 5, 2006 | 03:23 PM
  #16
ssean92's Avatar
Re: lt1 cold issue
what am i looking for. they go from 100-800mv's jumping back and forth
Old May 6, 2006 | 05:16 PM
  #17
HardcoreRM125's Avatar
Re: lt1 cold issue
Thats about right. They are supposed to constantly flucuate between 100-900mV while driving.
Under wide open throttle, they should stick up in the higher mV range like 800+ as the car goes into fuel enrichment mode where it richens the mixture out at full throttle.
Old May 7, 2006 | 08:19 AM
  #18
ssean92's Avatar
Re: lt1 cold issue
i have a power tune that is supose to lean it out at pt and wot i do need to hook my scaner up and see what it does. thanks for the advise.
Old May 13, 2006 | 12:07 PM
  #19
ssean92's Avatar
Re: lt1 cold issue
well the fuel pump seems to be the issue. what would cause the fuse to get so hot that is melts the fuse, dont blow it melts it. i changed the relay and still, could it be the pump?????? or is there anything else that would cause that, and also the tranny took a crap again so its out to get relooked at by my tranny guy
Old May 15, 2006 | 12:08 AM
  #20
Re: lt1 cold issue
If there is a short in the wiring, or the pump, it could draw too much current through the circuit which should blow or melt the fuse. Try and get some wiring diagrams for the fuel pump and start tracing the lines back. When the actual pump goes bad, I wouldnt think that it would literally melt fuses like that. Maybe blow one or two from inconsistant current draw but not like that ...
Old May 15, 2006 | 03:57 PM
  #21
ssean92's Avatar
Re: lt1 cold issue
yeah thats what i was going to do. i was trying to get my tranny fixed first then look into the fuel pump thing. i finally got me a truck so i wont need to drive this car everyday so i will be able to look at it right with out haveing to rush. thanks for the idea's
Old Jun 21, 2006 | 03:29 PM
  #22
ssean92's Avatar
Re: lt1 cold issue
well guys it was the f/p it seems to be fixed , well as best i can see with out the tranny still, still waiting for the tranny from tranny guy
oldschool
Feb 9, 2016 09:21 PM
Gtpguy
Jan 26, 2015 04:50 PM
Britbilly
Jan 7, 2015 08:49 PM
jayblev95
Dec 1, 2014 06:55 AM
