LT1 to a Carb
Old Jul 22, 2006 | 09:27 PM
383TransAm's Avatar
Question LT1 to a Carb
Well I have about had it with my fuel injection
Does any one know where you can buy a LT1 Carb Conversion kit and get rid of the ECM?
Give me some gauges and a 650 with 4 barrels and I will be happy.
Old Jul 22, 2006 | 09:36 PM
Dave89IROC's Avatar
Re: LT1 to a Carb
GMPP part # 24502592 for the intake, you will need a regular(gen 1) distributor, a carb, and throttle cable bracket
if you have a 94+ A4 trans, you need a aftermarket controller or a different trans
Old Jul 22, 2006 | 09:38 PM
383TransAm's Avatar
Re: LT1 to a Carb
93 6-Speed so I'm cool there.
Thanks for the info.
What else do I need to make it all work?
Old Jul 22, 2006 | 09:43 PM
QuickdomesticRacer's Avatar
Re: LT1 to a Carb
I have no idea, but can't you use the stock ignition on it? In my cousin's blazer his injectors get the signal to ingauge from the distributor. So he could put a carb on that and still use his distr in his truck it would just send a signal to "no where" for the injectors and the SES light would prob be on.
Doesnt the Camaro ECM distr control the injectors aswell? Than he would only need a conversion intake and a carb?
Old Jul 22, 2006 | 09:47 PM
383TransAm's Avatar
Re: LT1 to a Carb
I want to get rid of it ALL and go old school.
Old Jul 22, 2006 | 10:00 PM
Dave89IROC's Avatar
Re: LT1 to a Carb
on LT1s, the opti (distributor) sends signals to the ECM/PCM, and the ECM/PCM controls ignition and fueling
no direct connection/control between the dist. and ICM/coil(other the the coil wire/secondary ignition)
Old Jul 22, 2006 | 10:32 PM
LenT1's Avatar
Re: LT1 to a Carb
Don't forget you will want the optispark block off plate, which I happen to have for sale!
bose
Jan 30, 2015 02:36 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
