lt1 cam bearing question
Old Apr 28, 2003 | 03:15 PM
Brettinator's Avatar
I'm installing my own cam and want to know the feedback of changing the bearings. I have 72k for mileage. I've heard a mixed opinion on the street about this but would like some experienced feedback from here. I would not change my bearings until I done the stroker so it's not an option but I'd wait on doing the cam if it were likely to cause me premature engine failure due to the swap. Thanks for any feedback
Old Apr 28, 2003 | 03:17 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
unless the motor is being pulled, you cant change the bearings. they are't like main bearings-
they are PRESSED in hard. Reallly, only a machine shop can do it and I wouldn't worry about it
Old Apr 28, 2003 | 03:36 PM
While the optimum thing to do is to replace the bearings, the majority of people don't have a problem just swapping in a new cam.
Old Apr 28, 2003 | 03:43 PM
treyZ28's Avatar
rob,
have you even heard of anyone spinning/knocking loose a cam bearing on a street/strip car
wearing it down to the point where there is a clearance issue and the cam wabbles or anything?
Old Apr 28, 2003 | 04:19 PM
Originally posted by treyZ28
rob,
Hey...I thought I basically asked that same question...lol ..but yeah....that's what I'm trying to find out here
Old Apr 28, 2003 | 05:28 PM
Smokn '94 Z's Avatar
Lightbulb
I had the same dilema when I did my hot cam. I noticed the cam bearings were worn on the one side more than the other cause of the direction the motor turns. But after talking to many people they said as long as the bearings are not worn into discoloration & still have enough meat on them without getting technical in the actual mic'd thickness they said it should be fine. But no gaurentees.... I dedcided to go ahead & put the cam in & as of now my car is running great with solid O.P. I too will do an engine build up but not for a couple of years so I went for it. It should be fine. My car had 80,000 very hard but well maintained miles on them cam bearings. In a perfect, wealthy, world I would have pulled the motor. But I don't have them luxeries...
Good luck.
Old Apr 28, 2003 | 05:36 PM
treyZ28's Avatar
Good luck.
i'm wondering the results of too much clearance/wear in these bearings
Old Apr 28, 2003 | 05:48 PM
rob,
I don't hear everything , but not have heard of issues with cam bearings. A person could mic the bearings and the cam journals to see what kind of clearances there are. I am going to guess with the roller cam and retainer plate we have, chances of problems won't be prevalent. There are lots more LT1 engine building guys on here that probably have better opinions.
Old Apr 28, 2003 | 05:53 PM
I would imagine as long as sufficient oil gets between without a lower O.P. then I would say the odds of a bearing freezing up & spinning in the block would be as if you still had the stock cam. Infact I would think a new cam might even tighten things up a bit. But then again I am not a cam expert. I figured if it will fail with a new cam then it will with the stock cam just as easy. Maybe people who spin the motors a bit higher than stock (Like Me ) may have a better chance of something wrong happening. I have really yet to hear anyone who has done a cam, really come up with cam bearing issues. But I am sure it can happen & does.
And I probably just jinxed my self....
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Injuneer
Dec 15, 2014 09:36 AM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
