lt1 aluminum heads questions
Old Feb 20, 2007 | 01:50 AM
mrmint69's Avatar
I need to do something with my heads. There are 2 bolt holes in each end for mounting exhaust. Is one used for stock and if you go aftermarket you will use the other one? I assume the far end outside ones are factory mounting. What was the purpose for the one next to it and is this the one to use for Mac's or BBk? Did all 94Z's come with aluminum heads?
Old Feb 20, 2007 | 07:01 AM
All years F and Y body LT1 cars came with aluminum heads. B-body cars had cast iron. You use the holes that line up with whatever you are installing.
Old Feb 20, 2007 | 07:09 AM
SS RRR's Avatar
Since the LT1 head is a traditional "D" port design the outside bolt holes are left from heads of the past. Any aftermarket exhaust manifold/header flange should bolt up to the stock location.
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
