lt1/4l60e in a 82 caprice
Old Jul 8, 2005 | 10:05 AM
cause4panic's Avatar
So i recently started working on this sleeper, motor and tranny are in g force cross member is in, driveshaft, and column shift are in.
time to do some wiring i just have a few questions, i got all the wiring from shoebox's site, but i was wondering what a few of the connections are looking for or what i should do with them. please help guys.
96 trans am
c105 connecter
A Orange/Black Traction control system spark retard ?
C Tan/Black Traction control system throttle position?
E Tan Serial data signal
c210
A Purple Theft deterrent relay to starter solenoid feed
B Black/White Ground feed to fuel pump relay
D Red Feed from fuel pump and fuel pump relay to prime connector
c230
E Dk Blue Theft deterrent-fuel enable feed
h Lt Blue/BlackBrown (Automatic) TCC switched power feed
J Orange/BlackLt Green (Automatic) Park/neutral feed from transmission range switch (V8 VIN P only)
K Purple Output field service enable
1995-1996
Cavity Wire Color Description
A Grey 5v reference signal from PCM
B Dk Blue Sensor feed to PCM
C Black Ground feed from PCM
These are the only ones i dont really know what the computer needs, if i dont connect the traction control etc.... or theft stuff is this gonna cause problems? if i get all these things wired i think she should start right up
THanks
Old Jul 8, 2005 | 10:14 AM
WS Sick's Avatar
Re: lt1/4l60e in a 82 caprice
Ok I'll try to help, I just finished putting an LT1 in a 91 S-10 .
c105 connecter
A Orange/Black Traction control system spark retard ? Don't need
C Tan/Black Traction control system throttle position? Don't need
E Tan Serial data signal, Goes to the ALDL connector
c210
A Purple Theft deterrent relay to starter solenoid feed ,Goes from switch to starter
B Black/White Ground feed to fuel pump relay , ECM Provided Ground for small side of Fuwl pump relay
D Red Feed from fuel pump and fuel pump relay to prime connector , Was grey on mine with same purpose, it is Y-ed to the wire that goes back to the fuel pump.
c230
E Dk Blue Theft deterrent-fuel enable feed , Vats ,Dissable and don't use this wire
h Lt Blue/BlackBrown (Automatic) TCC switched power feed, To Tranny
J Orange/BlackLt Green (Automatic) Park/neutral feed from transmission range switch (V8 VIN P only) From Shifters switch can be used or not used, if left open will be fine.
K Purple Output field service enable , Have no idea , wasnt in my 94 harness.
I know that my harness is a 94 and some of the wires may have different purposes between the two years.
Old Jul 8, 2005 | 04:49 PM
thanks alot anyone else wanna help a first timer swapping an lt1
how do i easily disable the vats system?
Old Jul 8, 2005 | 05:01 PM
WS Sick's Avatar
If you have the vats module that was under the dash you can measure the resistance at the base of the steering column with the key in and put that size resistor inline (white wires out of the Vats module) if you dont have a vats module you can have it removed via tuning , any after market tuner like PCM for less for instance can remove it, or you can do like I did and buy tunercat and remove it yourself.
Youll need the aldl connector and power to the ECM, along with a cable that can hook from your laptop computer to the ALDL.
Or if you have a LT1 f-body you can put the computer you want to tune in it and hook your laptop to it to flash it.
Old Jul 8, 2005 | 05:44 PM
what does the vats module look like, cause i have the key and can find the resistance.
what should i do about these wires
1995-1996
Old Jul 11, 2005 | 01:18 PM
to the top
Old Jul 12, 2005 | 08:26 PM
camaroz28racer2's Avatar
I would either just get the pcm reprogrammed, or buy the vats module from painless wiring, jegs and summit both carry it I believe. Trying to keep the vats module and play games with that and your only asking for trouble.
Strick
May 26, 2015 11:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
guionM
15
Mar 22, 2003 02:44 AM
DaytonaFBody
Jul 22, 2002 10:26 AM
Airhead315
3rd Gen / L98 Engine Tech
Jun 8, 2002 08:14 PM
