LT1 383 camaro 97 tune help
Old Aug 5, 2012 | 10:09 PM
beto_mty's Avatar
Hello
I'm from Mexico, and I have a 97 camaro LT1 engine complete rebuild and swap to 383 which I just fixed and I have some questions about fine-tune the computer, please help because in mexico not get information about it, very thanks
383 kit cast eagle crankshaft, Hypereutectic flat top keith black pistons, 5.7 rods scat mallory balanced
OEM aluminum heads street porting job by professional with 2.0 intake valves and 1.6 exaust
Camshaft hydraulic roller crower .535 / .550 lift with 120 lbs springs and 1.6 rockers aluminum full roller
block deck milled for more compression
intacke ported
58 mm throttle body and modified maf for more flow
1 3/4 tube full length headers
36 lbs injectors
walbro fuel pump with aeromotive 100 lbs regulator
complete rebuild OEM transsmicion whit kit
2800 torque converter
410 rear end
electric water pump
drag tires
MadMav
Feb 6, 2015 11:02 PM
Collector Car
Dec 17, 2014 01:12 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
Burn_Out
Aug 18, 2002 08:49 AM
