LT1 383 build question
Old Oct 27, 2011 | 04:11 PM
rocknroler69's Avatar
I want the compression ratio somewhere between 10.5-11. Ive found a few combos that would work
54cc combustion chambers (stock 350 head) with a head gasket .080in =11.08 to 1 ratio
62cc combustion chamber heads with .039in head gasket = 11.17 to 1 ratio
64cc combustion chamber heads with .039in head gasket = 10.86 to 1 ratio
Which one do you guys think would be better for a STREET ONLY car, or do you have other thoughts and combinations. I dont plan on driving it everyday but would still want to be able to, this car wont see any track time
Any input helps
Old Oct 27, 2011 | 04:22 PM
Psycho's Avatar
Re: LT1 383 build question
Just put premium in it and forget it. You will be good to go.
Old Oct 27, 2011 | 04:24 PM
RamAir95TA's Avatar
Any input helps
Compression ratio is also determined by things like deck height, cylinder bore and piston valve reliefs/dish. Did you include them in your calculations? Since you're considering such a thick head gasket that leaves me to believe that you didn't. .080" is THICK and will result in a super wide quench - NOT good for power. Stock is .049". Most people go with a .028" gasket.
Also, for a street motor I would target something along the lines of 11.5:1 compression. Anything less and you're giving up free potential HP. There is no drawback in doing so.
Old Oct 27, 2011 | 04:25 PM
RamAir95TA's Avatar
I am going to assume this is a joke.
Old Oct 27, 2011 | 04:29 PM
would 11.5 be too high to run 93 though, by what ive gathered 11.5 is pushing it
Old Oct 27, 2011 | 04:33 PM
I also planned on using flat top pistons with 2 valve reliefs, =7.00cc. And i did factor in the cylinder bore which would be 4.030in. Deck i did not do
Old Oct 27, 2011 | 04:35 PM
+7.00cc, my mistake
Old Oct 27, 2011 | 04:46 PM
Psycho's Avatar
There is .31 c/r difference between the lowest and the highest configuration. Plus, small things like cleanup passes will change that. Whats the difference going to make? Differences in dyno hp? Back to back dyno runs have more error than the hp increase in .31 c/r.
Really. What's he going to use? Race gas?
I dunno, maybe I missed the point he was tring to make/ask.
oldschool
Feb 9, 2016 09:21 PM
Jrlt1
Jan 3, 2015 07:38 PM
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
squirrels
Jul 13, 2002 01:58 AM
