LT1= in need of a diet plan
Old Mar 2, 2003 | 06:11 PM
ucrazymonkey's Avatar
As everyone is aware our F-Bodys are heaving SOB's. I am searching for ways to make mine tip the scales at under 3300 LBS without me in it. Last time the car was weighed it came in at 3440 LBS so im looking to shed 141 LBS. Now since that weigh in my car has had the following done to it:
BMR Boxed Subframe Connectors,BMR Tubular LCA's w/ Relocating Brackets, Drag Air Bag on the R/R, Flowmaster Y-Pipe and S-Pipe and moved up to 3" exhaust from the headers to the cut-out.
Now I did however get rid of my 18" wheels and tires. I moved to Weld Draglights with Skinnies up front and E.T. Streets in the rear. The difference in this is like night and day. I believe my mods I did to me losing those heavy tires about canceled each other out. So I still should be around 3440 =/- LBS.
So where do I lose 141 LBS at? Floor mats, sway bar, spare tire and jack have been long gone. I have already changed to an Aluminum driveshaft.
I do not want to jepordize any saftey items and this is to still be a daily driver.
If I remove the rear seats and seatbelts along with the lether front seats I will drop 108 LBS. Now of course I will need to put at least 1 seat but would like 2 seats back in front. Anyone have any recomendations? Would like 2 seats combined to weigh no more than 58 LBS.
Still need 100 LBS. off!
Old Mar 2, 2003 | 06:24 PM
1.8ttolt1's Avatar
bump!
Old Mar 2, 2003 | 06:26 PM
Pandamonkey's Avatar
www.jennycraig.com
www.weightwatchers.com
Old Mar 2, 2003 | 06:37 PM
95TA8280's Avatar
Originally posted by 1.8ttolt1
bump!
Bumping after 13 minutes? We should really sticky that post about that for new users.......
Old Mar 2, 2003 | 06:38 PM
Calli's Avatar
how much does the back seats weigh ? and how ugly would it look to remove them? is there decent carpet under them ? or would someone have to layer some down ? i dont use my back seats for anything... i sit so far back its uncomfortable for anyone to sit back there.. and its just me and my gf anyways.... you think a decent 40 pounds ?
Old Mar 2, 2003 | 06:41 PM
Back seats weigh 29 LBS and the seat belts and rectractors weigh another 5lbs. Also remove the floor mats and your at 1.8 pounds. 35.8 LBS loss after removing the rear seating.
Old Mar 2, 2003 | 06:59 PM
K!D's Avatar
K!D
if you want a 400plus hp f-body, I'll sell you mine.
Old Mar 2, 2003 | 07:12 PM
Give me your engine and I will give you mine and $600 cash. You dont even use it to its potential anyways. At least I would use it and not drive like a sissy all the time Did I say that outloud
Old Mar 2, 2003 | 07:25 PM
lt1camaroman93's Avatar
get rid of the entire A/c system, put the delete pully in.. That should shave some good weight. Other than that im really not sure what else you coudl do.
Old Mar 2, 2003 | 07:26 PM
AlexBarabas's Avatar
LS1
Old Mar 2, 2003 | 07:43 PM
jakef2003's Avatar
Tubular K member, And upper and lower A Arms ?
Old Mar 2, 2003 | 11:48 PM
You can get racing seats like the Corbeau Forza that weigh around 16# each. Then you will need brackets to hold them to the floor. The adjustable brackets add 10# per seat. If you can live with a fixed seat mount, you can keep the bracket weight down to 2#.
The rear seat area is fully carpeted, except for the holes where the seat belt bolts go through, and a rectangular cutout about 2" x 8" where each seat cushion bolts down. I just leave the floor mats over the cutouts for street use, remove the mats at the track:
No rear seat.....
Other things to think about deleting would be the AIR pump and cruise control. A light weight hood will shed a few #.
Problem with a lot of the high performance add-ons like suspension, torque arm, trannies, SFC's, roll-bars is that they add weight like crazy. Last time I weighed my Formula, it was 3,760# with me (190#) in it. And that is a car with no A/C, no rear seat, Weld Pro-Stars/skinnies/QTP's. Roll bar, TH400, Gear Vendor, chrome moly driveshaft, Spohn TA are all weight adders.
Old Mar 3, 2003 | 12:20 AM
allmotorta's Avatar
I've got:
Lightweight hood
Aluminum DS
!AC
!EGR
!Air pump
!cruise control
weld draglites with skinnies
!back seat
!spare tire and jack
!swaybar
I lost a few pounds when I switched to true duals too...basically the total weight of a catback.
probably more
Old Mar 3, 2003 | 12:44 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
if mine doesn't sell...
!rear seats
fiberglass hood
carbeau
!air
!cat
!metal in my heads
!AC
TA wheels are 6lbs lighter than salads (street)
slicks and skinnies for the strip
3.5'' alum DS
!spare
!jack
! washer fluid/washer fluid resv (its only driven on nice days)
amongst other little things
Old Mar 3, 2003 | 08:33 AM
mongse_1's Avatar
My 2K3 weight reduction:
BMR tubular upper a-arm (mild steel)
BMR tubular lower a-arm (mild steel)
BMR tubular k-member(mild steel)
Bogart D-10s (8# front, 13# rear w/o tires)
TH400
smaller diameter converter
use smaller battery & move to rear
true duals(goodbye catback section!!)
VFN 'glass hood
!front hood struts
!rear hood struts
!ABS
!EGR
!AIR
!power steering
!A/C & condensor
!front crash support(replaced w/ intercooler)
!rear seats & belts
!rear sound deadening mat(10# believe it or not!!)
!front sway bar & links
!wiper resevoir
I also try to keep my fuel level around 1/2 tank if I go out to the track or street racing. You can always fill up afterwards.
Of course, a lot of this is offset by the roll bar going in, but it's a give and take situation.
EDIT: I'm also thinking about tossing the airbags. Billingsley Racing has a replacement steering wheel center for these cars for those of us who don't want the pillows popping if there's an accident.
