LT Header install, Need some HELP!!
Old Jul 16, 2012 | 01:32 PM
sabresfan's Avatar
installing a used set of FLP longtubes w/ highflow cats. Ran into a few issues.
1.) The biggest issue is the oil filter. It wont clear driver side header. We took it off to install the header and it wont fit back on because it wont clear the header. Dunno what to do????
2.) Need longer o2 sensors
3.) Smog pump hookups on top of headers dont fit the thread of the connector to the hoses, too skinny.
Old Jul 16, 2012 | 01:36 PM
Lt1son's Avatar
Re: LT Header install, Need some HELP!!
I can only offer input for 2,3... they sell o2 sensor extensions and if they dont fit maybe go to hardware store and see if they sell a reducer of somesort.. never ran into that issue with oil filter housing. sorry i cant help on that
Old Jul 16, 2012 | 04:10 PM
sabresfan's Avatar
does anyone know if an oil filter adapter would help me out here? gm part # 3952302
Old Jul 16, 2012 | 05:07 PM
Lilatlboy6969's Avatar
I'm pretty sure an oil filter relocation kit would fix that issue!!
Old Jul 16, 2012 | 10:01 PM
sabresfan's Avatar
I don't think a relocation kit is the best idea because it uses rubber tubes, that would be sitting right next to headers.
I'm going to try removing the oil cooler if its not removed already
i also found this, Corvette oil filter spacer LT1 92 93 94 95 96 | eBay
would it work with my camaro? if so would it clear my headers?
Old Jul 17, 2012 | 12:06 PM
ACE1252's Avatar
What oil filter type and size are you using? I'm using an ACDelco PF454(I think that's the numbers for it...I will verify when I get home today). Clears my long tubes with no issues. The filter is a little shorter than "standard".
You can see it to the left of the tubes here....
http://www.ace1252.com/images/1996_L...s/DSCN4013.JPG
Old Jul 17, 2012 | 12:27 PM
2QUIK6's Avatar
Yep the PF454 is a short filter, that's what I use as well. I think the tall version of it was the PF1218 iirc.
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
GigaMp3z
Feb 20, 2003 02:57 PM
