LT checklist...
Old Sep 8, 2004 | 11:35 AM
jbsupra89t's Avatar
LT checklist...
hey,
so i've decided on the jet-hot long tubes, ordering probably this weekend. my question is this: i'll list what i have down to order and any comments on what else to do is appreciated. thanks!
-headers (duh...)
-felpro gaskets from thunderraing
-stage 8 bolts
-plugs and wires
-02 extension (one, for the 94)
am i missing anything? do i have something i dont really need? and input appreciated, thanks again.
-J
Old Sep 8, 2004 | 12:14 PM
StickMaster's Avatar
Re: LT checklist...
02 extensions (2 for every car) youve got an 02 on each side
Old Sep 8, 2004 | 12:15 PM
Re: LT checklist...
Oh and as for your go away CAGS, just unplug it, its a 94, stick a 2.2k ohm resistor in there, good to go.
Old Sep 8, 2004 | 12:28 PM
GetaZforgetGT's Avatar
Re: LT checklist...
I also bought a role of Thermo Tape just as an extra measure.
Old Sep 8, 2004 | 12:41 PM
speed76demon's Avatar
Re: LT checklist...
y-pipe??
or are you having one custom made??
Also while I was doing mine I wish I would have replaced my motor mounts. Just a thought
Old Sep 8, 2004 | 12:55 PM
z28marine's Avatar
Re: LT checklist...
get the taylor OVC wire kit...
Old Sep 8, 2004 | 03:56 PM
jbsupra89t's Avatar
Re: LT checklist...
thanks guys appreciate it. yea forgot about one of the 02s, that'd suck...
and the y-pipe is taken care of. thanks again!
-J
Old Sep 8, 2004 | 04:04 PM
99BlackTA's Avatar
Re: LT checklist...
What exactly is the CAGS? And what does OVC stand for?
Old Sep 8, 2004 | 05:13 PM
z28marine's Avatar
Re: LT checklist...
Over Valve Cover wires
http://www.thunderracing.com/catalog...vid=4&pcid=104
bottom of page.... without them you more than likely will get a burnt wire from the headers.... i highly recommend it
Old Sep 8, 2004 | 05:22 PM
1 Nasty Bird's Avatar
Re: LT checklist...
how about a couple fresh O2s while your down there?
Old Sep 8, 2004 | 05:39 PM
Kataklysm's Avatar
Re: LT checklist...
CAGS is in a M6 car when it has the "first to fourth" shift. Its when you have to shift into fourth gear directly from first if you don't rev past a certain point. Disabling it just makes driving more enjoyable. OVC is "over the valve cover" which as said before is how spark plug wires are run to keep them from burning when headers have been installed.
EDIT : I recommend not changing the O2 sensors until a few weeks after the header install. The coating from the headers being burned off will ruin the new sensors. Leave the old ones in for a while.
Old Sep 8, 2004 | 06:12 PM
99BlackTA's Avatar
Re: LT checklist...
Ah, thanks a lot! I was kinda clueless about those for a while. I am about to put my long tubes on in a couple of weeks and they are ceramic coated. I just got taylor wires put on it 5 months ago and was hoping to leave them on there. Not sure what to do really. Money is tight...
Old Sep 8, 2004 | 06:18 PM
Birdman7389's Avatar
Re: LT checklist...
Just a heads up on your '94, you will only need 1 O2 extension. The other 02 hooks up fine without it.
Old Sep 8, 2004 | 06:28 PM
jbsupra89t's Avatar
Re: LT checklist...
thanks, and i actually read about NOT putting fresh 02s in during the header install, but wait a few weeks first...
-J
Old Sep 8, 2004 | 06:37 PM
Re: LT checklist...
FWIW I put in fresh 02's when I did my headers and didnt have any problems......
Its my understanding that the Jet-Hot coating is pretty bulletproof, and wont cook off....
