LT-4 valve Covers
Old Dec 14, 2003 | 08:01 PM
  #16
SVT Killer LV's Avatar
Those are promagnums in the pics. They clear with absolutely no problems at all. I got them at my local Chevrolet dealership, however, scoggin dickey, jegs, gm partsdirect and a billion other online retail stores sells them. They are actually made by Proform. I got them for like $120+tax. They don't leak a drop of oil from any of the holes.
Old Dec 14, 2003 | 08:11 PM
  #17
Tony Garcia's Avatar
LT4 Valve convers
Can you put Lt4 valve covers on LT1 heads? cus i think they look a hell of alot better
Old Dec 14, 2003 | 09:17 PM
  #18
Heatmaker's Avatar
Advanced Member
"AsianSensation" do you have any more pics of the covers on your engine bay...I saw a glimpse of the mon your website...they look awsome
ANd anyone ever do one of these?
THESE
Old Dec 14, 2003 | 09:35 PM
  #19
AsianSensation's Avatar
Scroll down to the bottom of the page for more pics of my engine.
http://www.97ta.com/lt4.shtml
And ya, they will work with LT1 heads. Corvette LT1/LT4 use them.
Old Dec 14, 2003 | 10:16 PM
  #20
Originally posted by Heatmaker
The LT-4 valve covers are pretty tall...
Not so. They are the same height as the stockers.
Old Dec 14, 2003 | 10:46 PM
  #21
kgkern01's Avatar
AsianSensation, those look pretty good, they go great with the fuel rail covers.
So Shoebox, since these are stock height, would they clear 1.6 RR w/GM847 cam, (.595 lift on exhaust side)? I don't have it now, but will in the future.
Old Dec 14, 2003 | 10:49 PM
  #22
Heatmaker's Avatar
Advanced Member
They look much larger than the stock ones from the car shows I've been too.
Old Dec 14, 2003 | 10:53 PM
  #23
I couldn't tell you. I really don't know how much room there is on inside height. My gut feeling is that they would clear just about anthing you put inside 'em. Clearance problems with stock covers is usually not height, but the webbing that is inside them for side clearance of wider rocker arms (like CC Pro Mags). The LT4s are roomier in that regard.
Old Dec 14, 2003 | 10:59 PM
  #24
Heatmaker's Avatar
Advanced Member
Stock
Vette
Old Dec 14, 2003 | 11:04 PM
  #25
Stock
Vette
Don't know how you can tell anything about height from those pics and those 'vette covers are not LT4 covers, anyway.
I have measured them. They are the same height. Not something I saw at a car show.
Old Dec 14, 2003 | 11:06 PM
  #26
Heatmaker's Avatar
Advanced Member
Thier the magnisium covers but they are bigger. The LT-4 covers have more clearance..most of the Vette Valve covers GM put out have more clearance for the rockers. Thats the only pics I can find of a Close up engine comparison.
Old Dec 14, 2003 | 11:25 PM
  #27
I have just measure them also. The composite and stamped valve covers are the same height.
But I will say the composite valve covers sits a little higher because there's a gasket channel/groove on the stamped valve cover. The lip of the heads falls inside of the stamped cover gasket channel/groove, if that makes any sense. On the composite valve cover, the valve cover gasket protudes out from the composite valve cover channel/groove and the lip of the head does not fall inside of the gasket channel/groove (at least, that's the way it sits on my AFR LT4 heads). The gasket is a different design too.
From memory, the composite valve cover seems to be roomier inside. But that's really from the webbing or lack of webbing on the composite valve cover design.
Old Dec 14, 2003 | 11:59 PM
  #28
Heatmaker's Avatar
Advanced Member
That makes allot of sense now
But what needs to be done to fit "Tall" Valve Covers on?
Old Dec 15, 2003 | 12:05 AM
  #29
kgkern01's Avatar
I know Summit sells something that allows you to use any side bolt SBC valve cover on centerbolt heads, I believe it is about $100
Old Dec 15, 2003 | 12:23 AM
  #30
then sealing issues would haunt me... i like what i did.. and my valve covers a ton more taller than stock
