LT-4 knock module woth it/benifits?
Old Feb 14, 2007 | 05:12 PM
apss's Avatar
thinking about getting knock module since i have a loud exhaust/dumped.is it worth the dough and what benifits should i see?looking for some input.
Old Feb 14, 2007 | 05:14 PM
Chris 96 WS6's Avatar
It only helps if you are getting false knock readings. If you aren't getting any knock retard, or if you are but it is due to real knock/pinging/detonation, then the LT4 KM won't help. In fact in the latter case it would make the situation worse.
Old Feb 14, 2007 | 05:19 PM
apss's Avatar
i'm not getting any pinging.how would i know if i'm getting retarded?
i coud'nt resist wording it that way.
Old Feb 14, 2007 | 05:21 PM
Well you need to be able to scan the PCM and read, among other things, KR at full throttle all the way through the RPM range. There could definitely be sub-audible pining.
Old Feb 14, 2007 | 05:23 PM
apss's Avatar
i'll hook up the Genisys tomarrow and see what i get.thanks
Old Feb 15, 2007 | 09:55 AM
What's the verdict?
Old Feb 15, 2007 | 11:43 AM
Antz97ZNJ's Avatar
If I had a .25 for everytime ive seen this post throughtout the years ...general answer is for 30 bucks and a ten second install why not...btw I didnt notice anything on my old 97, some say they felt a little smoother in the upper rpms.
Old Feb 15, 2007 | 12:00 PM
2000GTP's Avatar
Pretty much sums up how I feel about it.
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
