LT-1 vibration, ticking, random mis pls. help
Old Jun 25, 2006 | 09:28 AM
squeelyblue99's Avatar
Hey all,
I've done tons of searching on this but still can't pin it down. The cars throwing the P0300 random multiple misfire code. The plugs, wires, and opti are all under 2 yrs old. There is also a heavy vibration and a ticking sound that seems to be coming from the top of the motor (when driving it's like its right behing the dash.) The problem is worse under load (accelerating and AC). I did the wires myself so it's very possible one or more is now burnt. Before I go the plugs, wires, coil, opti route is there anything mechanical (especially up top) that can cause the random mulitple missfire code? It's a stock 97 lt-1 with a 1 yr old tranny. Any help would be appreciated as MANY of you know this is a very frustrating problem
Old Jun 25, 2006 | 11:48 AM
Re: LT-1 vibration, ticking, random mis pls. help
Vibration, ticking, miss...sounds like classic symptoms of an arcing plug wire.
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
greenzee28
Sep 25, 2015 04:29 PM
autoxr166
Sep 25, 2015 04:21 PM
Aaront810
Sep 11, 2015 11:24 AM
