LT-1 removal
Old Jan 20, 2003 | 07:58 AM
RobbyRob's Avatar
LT-1 removal
TPIS has a attachment for pulling LT-1 motors called the happy hooker makes it easyer to slide the motor in and out .
Old Jan 23, 2003 | 05:57 PM
bz7's Avatar
bz7
Where does it bolt into?
Could you also suggest some points for attaching a chain if I don't use the TPIS part? I'm pulling an LT1 for the first time, and I'm not sure what some sturdy attachment areas would be.
Thanks,
bz7
Old Jan 23, 2003 | 06:45 PM
Szii's Avatar
Happy Hoooker
It's a metal plate about 6" by 10" (approx) and bolts onto your air intake.
I have one but haven't used it yet. Since it bolts onto your intake (which is aluminum) it's still up in the air as to whether it's safe or not. Motors are heavy and I, like many others, are worried about stripping the intake bolts...
-Mike/Szii
Old Jan 23, 2003 | 07:21 PM
lt1camaroman93's Avatar
I have a happy hooker and am so happy that i bought it.. works great
Old Jan 23, 2003 | 07:31 PM
bz7's Avatar
bz7
What do you guys think of just putting some eye bolts into the block and then feeding a chain through it?
Where do people usually attach chain to hoist an LT1 up?
-bz7
Old Jan 23, 2003 | 07:43 PM
TriPinTaZ's Avatar
they jsut dropped my LT1 out of the bottom of the car....wheels and all. i was like WOW
Old Jan 23, 2003 | 08:09 PM
grendal's Avatar
Hard to do without a lift and a very large shop.
-Michael
Old Jan 23, 2003 | 08:28 PM
bz7's Avatar
bz7
I'm actually pulling the LT1 out of a wrecked Firebird. I have all of the accessories and wiring removed. I also removed all body frame in front of the engine with a sawzall. Removing it from the top should be the easiest, I just don't know how/where to attache the hoist without damaging anything. Any ideas would be appreciated.
Thanks,
bz-7
Old Jan 23, 2003 | 08:49 PM
neil350's Avatar
Dealer do that, when whats his face with the blue 95 got his 355 and blower they unbolted the entire subfarme from the car. Like some one said, you got to have a big shop for that. Most junk yards already have the motors out of the cars.
Old Jan 24, 2003 | 01:16 AM
You do not have to have a big shop and a lift to take the whole k-member out with engine and trans still attatched. The first time i took the engine out we droped it in my garge. Took a while to get the car high enought, but we made it. It sure is not a light thing to try and pull out fron under there once it is down though. I think that it is easier to take it out of the top though. But everyone has there own prefrence.
Old Jan 24, 2003 | 01:41 AM
bunker's Avatar
yep a friend of mine did it in a confined space.
Old Jan 24, 2003 | 07:02 AM
RobbyRob's Avatar
Unless you have the proper lifts, tools, and area. Dropping the K-frame is very dangerous. The happy hooker is safe and easy to use. You can check it out on tpis.com.
Old Jan 24, 2003 | 09:45 AM
CANTONRACER's Avatar
It is very easy to pull the motor from the top of the car. Some guys take off the front of the car(the nose), some don't. I don't, I just take out the radiator, pull the wp, pull the intake, yada, yada....
I pulled my motor 2 weeks ago. Started at 12:00 noon, buy 3:00, it was on the floor. Just me, my brother and my dad.
Old Jan 24, 2003 | 09:59 AM
94SLUG's Avatar
Just like pulling any other motor it you take the hood off you should not have to pull the heads. Unbolt tranny take off all harnesses and WP,ALT,RAD,FAN,COND,EXH. The alt and back of the head are good hook spots. Then the motor mount bolts and your done. That should take 5hrs max.
Old Mar 30, 2003 | 11:57 AM
notstock4long's Avatar
So you don't really need to drill any holes to get the engine out then? I heard that you have to take off the entire suspension to get these motors out.
