LT-1 Rebuild HP gains?
Old Dec 14, 2005 | 01:03 PM
cwaldt's Avatar
I've got two engine choices for my 95 Camaro. I know the othor routes hp/torgue figures. My question is what kind of power should I be looking at with the following figures.
LT-1 350 Block bored .30 over
Cam specs:
COMP CAMS Extreme RPM LT-1 Cam
Adv dur Int/exh 290/307 Dur .050 Int/exh 230/244 Lift Int/Exh W/1.5 .510/.540
Heads ported to match cam
Rollor Rockers 1.52 ratio 3/8" stud self aligning
and everything else head wise set up with the cam
PCM tune by PCM4less or MadZ28
Pacesetter long tube headers
X-pipe
Bullet Mufflers
What kinda out put should this give me. Also any suggestions or recommendations will be appreciated.
Old Dec 14, 2005 | 04:24 PM
Birdman7389's Avatar
Re: LT-1 Rebuild HP gains?
I'd guess you would put 330-350ish to the wheels? Hotcam+bolton cars (no headwork) with the M6 put down near 350, I'm not familiar with that cam,but who knows what exactly has been done to your heads?
Old Dec 14, 2005 | 05:02 PM
chy20k1's Avatar
with a good set of heads you should see 400 rwhp. id go with 1.6 nsa rockers though.
Old Dec 15, 2005 | 10:26 AM
cwaldt's Avatar
Thanks for the info. Deal went through on my other option so I'm gonna go that route.
Old Dec 17, 2005 | 01:23 AM
tony_mid's Avatar
Cam specs:
X-pipe
Bullet Mufflers
I'm also looking at rebuilding my motor and was wondering what all that is goign to cost?
Old Dec 17, 2005 | 02:59 AM
1racerdude's Avatar
Cam specs:
X-pipe
Bullet Mufflers
Keep your DCR as close to 9.0 as ya can,get 1.6 RR's,and a 58MM TB. If the cam is a 112+4 you are good. A 108+4 would be better.
G-BODYT56
Jan 14, 2022 11:14 PM
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
Ks0209
Oct 1, 2015 07:32 AM
Bxlt1
Sep 29, 2015 03:18 PM
