ls7 lifters in a lt1
Old Oct 2, 2008 | 12:12 PM
  #31
94zgreenmachine's Avatar
Originally Posted by mdenz3
When I checked mine I used springs that were just barely strong enough to hold the valve closed.
+1. Moroso check spring from Summit. Some folks have had luck at the hardware store finding a suitable spring.
Old Oct 2, 2008 | 03:22 PM
  #32
6SpdLT1Z's Avatar
Originally Posted by shoebox
As has already been said-measure!
I'm not spending $100 to measure and find out they're too short, then either selling them and taking a loss or spending another $200 on pushrods.
Old Oct 2, 2008 | 03:28 PM
  #33
Ok, well, it's less than a third of that for a checker and it you want to potentially destroy your engine or parts of it because you don't want to measure, then that's your call.
Old Oct 2, 2008 | 04:35 PM
  #34
6SpdLT1Z's Avatar
I'm just not going to go with them on the basis of what people've said and find ones that will retain the stock pushrod length.
Old Oct 3, 2008 | 11:48 AM
  #35
whyrun's Avatar
I was always taught That to measure CORRECT pushrod length you have to use a check spring and a solid lifter. I wouldn't advise using a operational lifter and spring if your wanting a absolutely correct measurement
Old Oct 3, 2008 | 12:13 PM
  #36
The check springs won't collapse the lifter(hydraulic). With solid lifters, you don't need the check spring.You can use the installed cam springs.
Old Oct 3, 2008 | 12:31 PM
  #37
whyrun's Avatar
Not trying to argue, but if you use a solid lifter and the inservice spring you could possibly cause flex in the length checker skewing your measurement. with the check spring you would know the exact point of zero lash when movement ocurred granted you've set up a dial indcator.. I'm sure one way is as good as another its just how techncial you wanna get. I try to finite adjust everything I can..
Old Oct 3, 2008 | 01:52 PM
  #38
wrd1972's Avatar
I disagree. I have tried the checking springs and found they still collapsed the lifter. I even went to the hardware store and got a very soft general spring, same thing happened. If the lifter has oil in it, test springs can work with border line acceptable results. If the lifter is not pumped up, forget about the test spring IMHO.
Simply put, the best way is to pull the intake and convert a lifter over to solid and check the PR lengths. I have also found that the Proform pushrod length tool matches what I find with the adjustable pushrod.
Old Oct 3, 2008 | 03:35 PM
  #39
My check springs were so weak, they barely pushed up high enough to keep the valve keepers in place. I had no problems, with my LS7 lifters, when checking pr length using a check spring. I did watch to see if they collapsed but they did not.
Old Oct 3, 2008 | 03:39 PM
  #40
What push rod tool are you using? I had a little movement (comp cams pro mag)but it couldn't have been more than .005, if that much. But, if you do want "perfect", nothing wrong with that , either.
oldschool
Feb 9, 2016 09:21 PM
Noer
Feb 28, 2015 11:29 AM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
Bearmans
Dec 3, 2014 05:28 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
