ls7 lifters
Old Feb 22, 2007 | 11:03 AM
fbodyboy's Avatar
ls7 lifters
i know you can install ls1 lifters in an lt1 motor. I also know you can install ls7 lifters in an ls1. So my question is, when i upgrade my vavle train should i install ls7 lifters into my motor? i know there good for over 7,000 rpms and are pretty cheap.
Old Feb 22, 2007 | 11:43 AM
jsetzer's Avatar
I can't answer as far as the ls7 ones, but I know that the lifters are the one thing in the valvetrain that if I had to cut corners that would be it.
What are you going to run? Lots of us are on stockers still.
Old Feb 22, 2007 | 12:20 PM
Colin91Z's Avatar
Check out this thread for some good lifter info
http://web.camaross.com/forums/showthread.php?t=501293
Old Feb 22, 2007 | 03:47 PM
Chris 96 WS6's Avatar
I'm pretty sure the LS7 uses a set of special offset lifters...so I wouldn't assume they will work.
Old Feb 22, 2007 | 06:28 PM
fbodyboy's Avatar
i know they drop right in into an ls1 without any modification, i just did the install over the weekend on my friends. i understand the lifters aren't the weakest point on the motor but i dont want to cut corniers on anything. i was just going to upgrade to 1.6 rockers and stronger pushrods and was thinking maybe i should go ahead and replace the lifters anyway.
Old Feb 22, 2007 | 07:41 PM
speed_demon24's Avatar
LS7's will work fine.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
mrwz28
Jul 8, 2015 09:11 PM
