LS1 swap w/ LT1 electronics....
Old Apr 21, 2005 | 03:57 AM
disco192's Avatar
So I was thinking about this...
Would it be possible to run a LS1 off of an LT1 wiring harness with some modification. The only main problems I could forsee would be ignition and fuel control.
I think if there is a way to use the LS1 crank signals into the computer, then that would fix all ignition issues if you used an LTCC or Delteq.
Then you have the fuel system... I would imagine that you could just run a custom return fuel system on the LS1 and it should run fine... right?
You would prolly need a LT1 knock sensor as well.
I think it would be a cool project and might make tuning easier and simpler while retaining all the stock wiring.
Just playing with ideas in my head.
Old Apr 21, 2005 | 04:46 AM
94zgreenmachine's Avatar
Re: LS1 swap w/ LT1 electronics....
I would think the knock sensor is completely different. A 305 has a different knock sensor than a 350. I would also think the blocks material would also play a part in how the knock sensor would work.
Why not run a F.A.S.T. system or the like and have the ultimate in tuning control?
I know you say your kicking the idea a round but I suppose if you like trial and error stuff then go for it
Old Apr 21, 2005 | 08:32 AM
trax's Avatar
In a word... why?
The LS1 PCM and LS1Edit allows more powerful tuning than an LT1 PCM. As I see it, you would actually lose tuning flexibility.
Old Apr 21, 2005 | 08:36 AM
madwolf's Avatar
In two words - not possible.
Old Apr 22, 2005 | 10:23 AM
1-bad-z28's Avatar
that is what i was thinking^ If you went through the trouble to install an ls1, why wouldn't you just get the harness to go with it? An lt1 harness and pcm wouldn't work reguardless.
rocketman051894
Jan 30, 2015 03:23 PM
ddr698
Jan 9, 2015 10:05 AM
cmdeshon
Jan 4, 2015 11:15 AM
Jul 4, 2005 05:00 PM
