LS1 swap
Would I have to make any changes to make a LS1 fit into my 97Z28? Would it drop in pretty smoothly and would an aftermarket header and exhuast combo match up?
Re: LS1 swap
It should bolt right up to the motor mounts...
but i've read where you need a 98-99 LS1 because of some electrical hookups. LS1 radiator, fans, and prolly alot of other stuff that i forgot. also, why the swap? did the LT1 crapout or did you get a good deal on an LS1 somewhere? Cause why spend 4-5k just to be as fast as every other Camaro/TA? Mod the hell out of that LT1 man. :D |
Re: LS1 swap
mechaniclly, you need LS1 k member, LS1 trans, LS1 radiator, aftermarket hood
Re: LS1 swap
^^see i told you there was a whole lot of stuff that i forgot :D
Re: LS1 swap
LS1 Trans? The Tranny won't bolt up to it? Isn't it a T56?
Re: LS1 swap
same tranny..diff. bellhousing
Re: LS1 swap
Its a lot cheaper to mod your LT1 than it is to install an LS1 in place of it... and it will most likely be a lot faster too.
Re: LS1 swap
also I heard about something with the fuel lines or something...i forgot though...
~Kevin |
| All times are GMT -5. The time now is 07:58 AM. |
