ls1 exhaust on lt1
Old Jan 6, 2005 | 05:36 AM
irishz28's Avatar
ls1 exhaust on lt1
has any one put the exhaust off a ls1 car onto a lt1 car using the slp adaptor kit for loudmouth?
Old Jan 6, 2005 | 05:05 PM
irishz28's Avatar
Re: ls1 exhaust on lt1
nobody?
Old Jan 6, 2005 | 05:47 PM
TransAmGT's Avatar
You don't even need the adapter kit! I just sawsalled the s-bend out of the stock exhaust on my brothers '95 Z28 and grinded it down a little...put a clamp on it and it doesn't leak at all! Give it a try! He is using a Loudmouth off a LS1 btw!
Old Jan 6, 2005 | 07:47 PM
Bersaglieri's Avatar
I used a LS1 GMMG on my 94 LT1. It took a bit of fabrication but worked in the end. Of course its easier to adapt with LT's and an ORY. Good Luck.
-Dustin-
Old Jan 6, 2005 | 08:12 PM
lt1zpwr's Avatar
why were u looking at an exhaust that is made for an ls1 and not an lt1 cauze most companies make em for both
Old Jan 7, 2005 | 01:38 AM
Probably the same reason I did. I couldnt help but jump on saving over $350 on a slightly used LS1 GMMG.
-Dustin-
Old Jan 7, 2005 | 01:43 AM
turbo_Z's Avatar
Any moderately good exhaust shop should make it work. I believe all youd really need is whats called and S-pipe to button it all up. SLP makes them. If Im not mistaken the LS1 systems are pretty much the same as the 96-97 so speaking from experience in that right.. youd need an S-pipe unless of course you have LTs and y-pipe.
Brake_L8
Jan 20, 2015 09:44 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
