LS1 brakes, Is this everything?
Old Feb 9, 2003 | 11:47 AM
Tibbys96Z's Avatar
Here is what I got for the LS1 brake upgrade. Do I need anything else?
http://us.f1.yahoofs.com/groups/g_85...MVpR.Av6cOCEyF
http://us.f1.yahoofs.com/groups/g_85...MVpR.AYHhxi24J
That little metal piece at the end of the brake line is pinched off. Looks like it was cut with some cutters....What is that piece, and what should it look like?
Try these:brakes1
another pic
Old Feb 9, 2003 | 12:27 PM
Ryan94ZA4's Avatar
Well, I can't view the site but here is what you should have:
Spindles
Rotors
Calipers
Hub/ABS sensor
Brake line from caliper to body
Bracket to bolt to body
I am guessing the piece you are talking about that is pinched off is just the line off of the car. You will unscrew that and screw your cars line into it. You will have to bend your lined a bit to make it fit right.
Ryan
Old Feb 9, 2003 | 03:21 PM
Tibbys96Z's Avatar
Good deal. Sounds like the only thing I didn't get is the bracket.
Do the links work now?
Old Feb 9, 2003 | 07:49 PM
shocktrp's Avatar
Links not working. Here's mine;
Prep: http://www.fbody.com/tech/details.cgi?id=29
Install: http://www.fbody.com/tech/details.cgi?id=30
Old Feb 9, 2003 | 08:33 PM
Tibbys96Z's Avatar
yahoo seems to be having some troubles...
Thanks for the link. Looks like I'm good to go!
alex5366
Jun 8, 2015 07:52 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
