LS1 Brake Upgrade Problems
Old Feb 22, 2004 | 04:42 PM
JOE96Z28SS's Avatar
Unhappy LS1 Brake Upgrade Problems
Do I need to upgrade my master cylinder?? The car just doesn't seem to have enough power to apply the brakes! I know I b1ed it thouroughly Please advise Pedal hits rock bottom and I relly have to press to get anymore outta it, I can't drive it like it is because it's that weak?!?! And when I say rock bottom I don't mean to the floor After about 1 Inch of travel the pedal mid as well be on the floor cause it's going no further!
Old Feb 22, 2004 | 07:57 PM
Janny's Avatar
You don't need the MC. I did the LS1 brake thing and they are great! You have other issues, and will need to investigate further, because your brakes should also be great!
Old Feb 22, 2004 | 08:01 PM
Kataklysm's Avatar
good advice
Old Feb 22, 2004 | 08:15 PM
1msfyter's Avatar
Both bleed screws tight? Did you have any previous brake problems before the install? Bled the ABS unit also?
Old Feb 23, 2004 | 08:13 AM
JOE96Z28SS's Avatar
My brakes were never powerful, How do I tell if it's My ABS Module?? My booster does Hold Vacum I guess that's not proof thatit's working though
Old Feb 23, 2004 | 11:45 AM
Janny's Avatar
Are the pads and rotors new? If they are a mismatched used set you could get very poor braking performance. If they are new, you may just need to "bed" them in. I know what you mean when you talk about really poor brakes. My original brakes were so lousy, I couldn't lock the wheels under any circumstance. This was corrected with a better pad; they were remarkable strong with a set of Carbon Metallics. Of course, they became much better again with the LS1 kit.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jazsun
Dec 29, 2014 12:14 PM
