Lowering springs
Old Feb 22, 2004 | 05:43 PM
ScottZLT1's Avatar
Lowering springs
I am going to use eibach pro-kit springs and blistien shocks on my car to make it ride alittle better. Will i neeed an ajustable pan hard bar, and is it worth replaceing the rear control arms?
Old Feb 22, 2004 | 06:11 PM
1msfyter's Avatar
Yes you will need an adjustable panhard if your car is lowered to center the rear end. Plus they arent that expensive and stronger over stock. BMR makes great panhards and Lower control arms.
Old Feb 22, 2004 | 11:15 PM
96SSM6's Avatar
I lowered my car with the sportline kit and had no centering problems...maybe i was lucky. I didnt go for the pro kit because i knew id get used to the look and later wish it was lower. Im very happy with the SLs, you should consider them, they give the car a nice...mean look.
Old Feb 24, 2004 | 07:32 AM
ScottZLT1's Avatar
How do you measure to see if the rear wheels are centered, and if i do lower the car will it still ride like a rock?
Old Feb 24, 2004 | 07:39 AM
ScottZLT1's Avatar
And you said somethin about BMR lower control arms what dose that relaction bracket do, does it help lower the car or are they just long for better handleing?
Old Feb 24, 2004 | 08:48 AM
ledfootz28's Avatar
when u lower the car the control angle changes and to get the traction back u have to center the arm again,thats what the brackets do.
Old Feb 25, 2004 | 01:07 PM
ScottZLT1's Avatar
Old Feb 26, 2004 | 06:12 PM
ScottZLT1's Avatar
Has anyone used the bilstien lowering kit, does it work as well as the eibach?
Old Feb 26, 2004 | 06:17 PM
cndctrdj's Avatar
i got the thunderracing kit and i love it. it came with everything you need and it was a good deal
Noenav
Mar 1, 2019 07:38 AM
thenewkid
Apr 12, 2015 07:42 PM
ModdedNerd
Dec 25, 2014 05:51 PM
Dec 1, 2014 08:08 AM
thenewkid
Nov 27, 2014 09:41 AM
