lowering question
lowering question
OK, I've bought Eibach prokit springs and they will be going on with a set of Bilstein HDs I am going to purchase from Strano. I knoow this will lower my car by about 1.4 inches but I ahve heard rumors about needing to get an adjustable panhard rod or something like that if i lower the car. true or complete fallacy?
it's a 97 z28 'vert in case it matters.
OK, so I need an adjustable panhard brace and relocation brackets? Could you guys go into a wee bit more detail as to what in the hell those are and are their aftermarket options or will GM Parts Direct be my friend on this one?
Relocation brakets are aftermarket only. They change the lower control arm mounting points on the rear axle housing to compensate for lowering. They basically lower the mounting point so where the lower control arms attach to the axle housing it is still lower then the body because when you lower the body they are then more level and that is not an ideal thing. You could get wheel hop and traction lose. From a performance standpoint LCA Relocation brackets would be the first thing you would want to get but IMO you should get an adjustable panhard rod. Do you really want to be driving around with your back wheels ~0.5cm more to the passenger side then the front ones? I wouldn't.
As for LCA relocation brackets make sure you get weld-in ones! http://www.spohn.net/category.cfm?categoryid=1042
oldschool
Feb 9, 2016 09:21 PM
HectorM52
Jan 31, 2015 07:29 PM
