lowering the car...
Old Jun 18, 2003 | 12:50 AM
GoTopless95Z's Avatar
lowering the car...
Ok guys time for some help....I went and got the Eibach Sportline Spring and a set of 8 way adjustable KYB shocks...so I go to put them both on and after looking at the control arms on the front of the car I realize I need to put new bushings in everything so I pick up the Energy Suspension Master Bushing Kit...now the tough stuff. What more will I need to finish this lowering? I'm thinking once i get all the old bushings out of the old control arms and get them all cleaned up and painted I should be able to slap everything together and then get an alignment and be all set...any suggestions?
Old Jun 18, 2003 | 01:52 AM
norcalstreet's Avatar
BMR relocation brackets.
A must have for lowered cars. You can get weld-in or bolt-in types. Weld-in is stronger and cheaper. Checkout my site at http://www.norcalstreet.com for pricing.
I would recommended ditching the stock control arms all together and get some aftermarket control arms as well.
Old Jun 18, 2003 | 09:24 AM
problem is i recently lost my job due to an indefinate lay off so funds for the car a running out, do I need the relocation brackets in order to lower the car or will it be ok for a while if I just use the stock control arms and the shocks and springs? I really need to get the car running so I can drive it or sell it if times get any worse.
Old Jun 18, 2003 | 10:04 AM
Yes, your car will be fine without relocation brackets but get them ASAP when you can offered them.
Old Jul 9, 2003 | 05:47 PM
ucnu112's Avatar
I think I'm in a similar situation. I just received some Jamex lowering springs in the mail today. I was looking at contol arms too, as my bushings are shot.
From what I understand, my process from now would be to install the springs, new control arms and relocation brackets? Is there a certain kind of control arm I should look at? I see there are static ones and some that are adjustable. I'm not going to do much more than daily driving and the occasional stoplight challenge for now.
Am I missing anything? I don't want to forget something important.
Fred
Old Jul 9, 2003 | 06:42 PM
Adjustable ones are pretty much just for center the wheels. You can use the adjustments to gain optimal traction but gains would be minimal and that would be for only the most hard core dragster. Generally speaking you don't need them but when lowering your car an adjustable panhard bar may be needed to center the rearend. Relocation brackets I consider a must for any lowered car.
Old Jul 9, 2003 | 06:47 PM
ucnu112's Avatar
Just so I'm clear, I'll should be installing:
- Lowering Springs
- Control Arms
- LCA Relocation Brackets
- and an Adjustable Panhard bar
correct?
Old Jul 9, 2003 | 07:00 PM
That is what I recommend.
Old Jul 9, 2003 | 07:24 PM
bruecksteve's Avatar
I would change (in addition to all the above) your front sway bar.
Old Jul 9, 2003 | 07:28 PM
Are we talking FRONT control arms or REAR control arms?
Old Jul 9, 2003 | 07:29 PM
ucnu112's Avatar
My original thought of looking at control arms is that the bushings are shot. I wasn't able to find the bushings separate from arms.
If you say I don't need new control arms, then what specifically should I get for my particular application?
ps, I'm talking rear control arms.
Old Jul 9, 2003 | 07:48 PM
Ok, rear control arm bushings. You have several options there.
1. New GM replacements (1LE bushings maybe)
2. Poly bushings both ends (not recommended)
3. Poly/Rod End not as bad
4. Rod End/Rod end now we're talkin' noise but fun
You good at putting things together? Want to save some money?
http://www.jonaadland.com/Z28/Mods/L...minumLCAs.html
http://home.earthlink.net/%7Ejonaa/AluminumPHB.html
n2oblkz
Oct 22, 2015 02:31 PM
n2oblkz
Oct 12, 2015 01:53 AM
Hal Fisher
Sep 30, 2015 09:03 PM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
alliance12364
Sep 23, 2015 12:40 PM
