Lowered Z28 exhaust options?
I am thinking about doing something different with my exhaust. My tips look like crap and would rather just having nothing coming out the back. I was going to do true duals, but I lowered my car 2 inches...........I scrape everything now as it is. What if I had a bullet muffler welded right after the Y pipe where the headers meet and then run a few feet of pipe back to the axle and dump it? Has anyone done this? Is that a stupid idea? Anyone have a better idea? -Thanks -Brad
I'd be kind of worried about having a muffler attatch directly to the HEaders liek that....Thinking "back pressure" i dunno....but I saw an undershot of the sunocco 6 Camaro. It had headers then some type of crap. couldn't tell...but it dumped out the sides for exhaust. Headers then a muffler can work...but it kind of defeats the purpose. You atleast wanna have a little pipe...unless your registered in the NHRA Pro class
Sorry I wasn't clear I would have my headers then about a foot of pipe then a bullet muffler then about 3 feet of pipe then a dump to the ground right before the axle. -Brad
I'm more or less wondering how the set up I talked about above would sound and perform. I know that the setup I listed above will work. I had my car on the lift today and my tech said to give it a try and that he thinks it would work. He was just worried about sound and performance. -Thanks ----Brad
I have alreay figured out speed bumps, driveways, ect.........its all about angles.
my cars not lowered and my long tubes scrape on everything, especially when i am carrying a passenger...and dont even think about loading up 4 people and expecting to not scrape...if ur car is lowered 2 inches, i would go mid lenghts and then dump it...but long tubes WILL scrape
Have you looked into the OVAL pipes that are offered? I plan on doing this eventually along with getting uncoated long tubes. I would then fit the LT's and then cut the collector off and re-weld it to a better angle following the floorpan lines.
First I need to drop this sucker though.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jul 4, 2005 05:00 PM
. then get some long tubes, and say @#)$& inclines, speedbumps, and driveeways.
