Low voltage...
Old Jul 13, 2007 | 04:32 PM
'94 Bad A Z28's Avatar
Low voltage...
... assuming alternator and battery are fine what else could cause low voltage? Nothing on, just an idling/driving car.
Old Jul 13, 2007 | 04:38 PM
n2ceptor's Avatar
Loose connections...... Corrosion in wires/battery terminals.... Old/worn wires...... Etc....
Old Jul 13, 2007 | 05:04 PM
ricehammer's Avatar
Ground cable connections next to the coil.
Old Jul 13, 2007 | 06:03 PM
So far everything mentioned looks fine and is nice and tight.
Old Jul 13, 2007 | 08:19 PM
ricehammer's Avatar
Where are you measuring the voltage at?
Old Jul 13, 2007 | 10:52 PM
I haven't yet, for now I am just going off the stock gauge. Upon start up it reads ~13amp, once the car warms up it drops to the 12-11amp range.
Old Jul 13, 2007 | 11:01 PM
That volts, not amp on the gauge. Read it at the battery when you see it low on the gauge. I bet it will read fine at the battery. My theory is that the ignition switch and it's connections cause a voltage drop.
Old Jul 16, 2007 | 01:11 PM
Lol... I don't know why I said amps in that post, I wrote voltage in the title, haha.
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
68camaroboltz
Oct 5, 2015 01:46 PM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
