low speed fan problem
Old Mar 23, 2004 | 08:32 PM
tintagel's Avatar
i have a 94z28 with twin cooling fans...i did the fan mod and the low speed fan isn't working and i'm not positive it was working before i did the mod...i swapped relays around and checked fuses so now i'm wondering if there is a way to check the fan itself???can i tie into the wires right by where it plugs into the fan and run the positive straight to the battery and ground it to see if it works before i have to replace it???any help would be appreciated...
Old Mar 23, 2004 | 09:00 PM
slopokrodrigez's Avatar
12 volts and ground straight to the fan works every time. Unless the fan is optifriggen.
Old Mar 23, 2004 | 09:06 PM
tintagel's Avatar
that's what i was hoping to hear...thanks a bunch...
Alex Barnes
Jan 24, 2015 10:21 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
