Low Oil Sensor Replacement
Old Oct 25, 2005 | 09:28 PM
Evil Eric's Avatar
This thing is leaking like crazy on my car, im assuming its comin gthrough the sensor because its as tightened as much as it can possibly can be. Does the sensor simply back out of the pan or do you have to drop the pan to get it out? did a search diddnt find anything about the actuall replacement of the part....
Old Oct 25, 2005 | 09:46 PM
Dan Parker '96's Avatar
Re: Low Oil Sensor Replacement
Go to your GM dealer and order the new sensor. It will be different (all plastic with an integrated seal). This is different than the metal version with the metal/rubber gasket that you currently are using.
The new version works well.
Old Oct 30, 2005 | 11:45 PM
Evil Eric's Avatar
but before i try to pull it out is it a screw in sensor or does the pan have to be dropped?
Old Oct 31, 2005 | 12:17 AM
homey's Avatar
It just unscrews, not hard at all!
Old Oct 31, 2005 | 01:18 AM
MentalCaseOne's Avatar
The sensor leaks oil but not at the thread point... buy a new one.
HectorM52
Jul 30, 2017 11:46 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
Jazsun
Dec 29, 2014 12:14 PM
