Low oil sensor.
Old Apr 12, 2006 | 02:16 AM
LT1 POWR's Avatar
Low oil sensor.
So my low oil sensor craped out on me and im going to put a new one in next oil change.
Im wondering if I should put anything on the threads like locktite, RVT sealant or plumbers tape. It didnt come with anything either on the threads or in the box.
Old Apr 12, 2006 | 08:16 AM
Stoopalini's Avatar
Re: Low oil sensor.
No need to put anything on the threads. If I remember correctly, there's a brass washer seal already on it.
Thomas.
Old Apr 12, 2006 | 08:19 AM
FastZinTennessee's Avatar
Re: Low oil sensor.
I believe the one I got has an o-ring of some sort on it. Regardless if you have an o-ring or washer, I don't think putting anything on the threads is necesary.
Old Apr 12, 2006 | 03:21 PM
LT1 POWR's Avatar
Re: Low oil sensor.
Yeah i just looked at it and it has a rubber o ring on it.
Old Apr 12, 2006 | 04:00 PM
Jazsun's Avatar
Re: Low oil sensor.
Just a heads up. Your not gonna be able to replace it w/ out dropping the y pipe. I tried replacing mine on my 96 and you cannot get the sensor out w/ out it hitting the ypipe. Its very long, and goes into the pan deep. Thank you GM! The reason why Im replacing mine is because its leaking like a ****. It sitll works tho.
Old Apr 12, 2006 | 04:30 PM
Stoopalini's Avatar
Re: Low oil sensor.
I didn't have to remove the Y pipe on my car to replace it?
Old Apr 13, 2006 | 12:37 AM
LT1 POWR's Avatar
Re: Low oil sensor.
Ive got longtubes and an ORY and ive already looked to make sure it would come out without too much effort. Thanks for the heads up though.
Old Apr 13, 2006 | 03:43 PM
Jazsun's Avatar
Re: Low oil sensor.
Prolly because you dont have the stock y pipe.
Old Apr 13, 2006 | 04:46 PM
Stoopalini's Avatar
Re: Low oil sensor.
Yea, you are probably correct ..... although the Random Tech pipe has the same routing as the stock one, the driver's side cat is relocated next to the passenger's side cat.
Thomas.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
carl.froehlich
Mar 13, 2015 12:38 AM
