Low oil pressure when idling
Old Jun 10, 2004 | 04:06 PM
  #16
Kurt Crosbie's Avatar
Well, would the noise be instantaneous upon the initial reading of 0psi?
If not, how long would it be before it started tapping?
And seeing how this change was all of a sudden, is it more likely that it is the sending unit, pump, or an actual bearing?
Old Jun 10, 2004 | 04:20 PM
  #17
96 WS6's Avatar
Are you using 5w30???
Old Jun 10, 2004 | 05:18 PM
  #18
You know, You already have a thread about this. Why hijack this one? Replace your sending unit as suggested in the other thread.
Old Jun 12, 2004 | 02:57 PM
  #19
Spllouder's Avatar
thanks shoebox for the pic . iam not sure but i think i have a early model 94 . was bought in early 94 and think rembering reading the window sticker was made in march. could i tell by my vin # ? how do i find this out ? i lost my oringal papers when i bought it back in 94 ?
i havent checked the sensor yet looks hard to get to if it is on the back of the motor . is it hard to get to if its by my oil filter probally not ?
Old Jun 12, 2004 | 03:12 PM
  #20
Spllouder's Avatar
ok nvm mind i just went out to my car and yes the sending unit is back there i can feel it. i would of never new where it was w/o out that pic . thanks again shoebox. so my car is a late 94 .it was 10 years ago thou
and yes i use castrol 5-30w and a autolator oil filter. i had a gm oil filter on there before i just changed my oil and same readings .
where do i hook up a mech gauge at ?
Old Jun 12, 2004 | 03:37 PM
  #21
You can do it more easily right here.
Old Jun 12, 2004 | 04:14 PM
  #22
94TEALz's Avatar
Mine would do the exact same thing after I changed to 5w30 when previously i had w40 in it. Then the oil pressure really started to drop after adding a can of "engine restorer"(wich is crap by the way),I changed back to castrol 10w40 and now everything is peachy.
HectorM52
Jul 30, 2017 11:46 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
jayblev95
Dec 1, 2014 06:55 AM
Jul 4, 2005 05:00 PM
