Low oil Light??
Old May 1, 2007 | 09:47 PM
Red97LT1's Avatar
Question Low oil Light??
Been getting a low oil light for the last few days,but the oil level is fine. It will come on and then when I start the car again it will go off. Would a loose wire or a sensor going bad cause this?
Old May 1, 2007 | 10:20 PM
SkiBumDreams's Avatar
Sensor or wires yup. mine does the same thing because the wires are broken. the wires come out of the rest of the harness where the o2 does and runs down behind the drivers side head.
Old May 2, 2007 | 09:29 AM
OBE1 95Z28's Avatar
The sensor mounts in the driver's side of the oil pan. Yes a bad sensor, sensor connector or a break in your harness could give you a false reading.
Old May 2, 2007 | 12:12 PM
Red97LT1's Avatar
Thanks!
transam_388
Mar 15, 2015 11:53 AM
Jan 23, 2015 01:13 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
