Low coolant light stays on...
Old Oct 24, 2003 | 03:34 PM
Slomaro's Avatar
Hello all. The low coolant light keeps coming on in my dad's '97 WS6 despite having plenty of fluid (I've checked it cold and hot, running and not.) Any ideas???
B.J.
Old Oct 24, 2003 | 03:46 PM
zhevy-1's Avatar
Most likely, your low coolant sensor gone bad. It's located on your radiator. It's normal for those to go bad.
Old Oct 24, 2003 | 03:48 PM
94GrayV6's Avatar
The low coolant sensor could be bad. You can either replace it or just unplug it. Either way, the light should go off.
Old Oct 25, 2003 | 08:21 AM
Lt1tko5o's Avatar
Those guys got it right, I have replaced the low level sensor in about 10 cars now, they go bad alot after a few miles. That has always been the problem.
Brian
Old Oct 25, 2003 | 08:43 AM
96blkform's Avatar
yip, mine is the same at the moment, light is on and fluid level is good. I need to replace mine, but it is just expensive $40 for the sensor. Does anyone know where to get it cheaper? I think I need the 2 connector as I have a 96. Thanks
Here are the part numbers
Here is a link to replace it
Old Oct 25, 2003 | 10:26 AM
Transamdriver's Avatar
I unplugged it.
Old Oct 25, 2003 | 11:56 AM
dkeers's Avatar
Mine is unplugged also. No light.
Magenta_Hearts
Mar 29, 2017 08:54 PM
eazyZ
Mar 1, 2015 07:12 AM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
