Low coolant light came on, but its totally full.
Old Jul 28, 2005 | 08:56 PM
lamb110's Avatar
as the title says my low coolant light came on, I checked the coolant in both the over flow tank and the radiatior. They were both fine, i put in a 160 degree thermo. about 5k ago and its been fine since. It hasnt overheated at all even though we have had some really hot days here in DC, like 90+. Could the sensor be screwed up, and if it is were is it located.
thanks
Old Jul 28, 2005 | 08:58 PM
Z28whiteboy's Avatar
Re: Low coolant light came on, but its totally full.
Yea that's a common problem with every lt1, the only thing you can really do to get rid of it is disconnect the sensor.
Old Jul 28, 2005 | 09:02 PM
lamb110's Avatar
lol cool, i thought i was going crazy, i checked it like 3 times and its always been fine, were can i disconnect it at? i really didnt look or anything just being lazy and thought i'd ask first
if i disconnect it will it throw a SES?
Old Jul 28, 2005 | 10:05 PM
simple's Avatar
could also be air trapped in the system
Old Jul 28, 2005 | 10:51 PM
Location. It won't cause a SES if disconnected.
Old Jul 28, 2005 | 11:38 PM
meangreen661's Avatar
pull if off and clean the sensor out. mine just got gunked up and needed to be rinsed off. i def would not just leave it disconnected thought.
Old Jul 29, 2005 | 12:23 PM
1StockZ's Avatar
Have you ever replaced your stock water pump? I just blew a head gasket because I ran the block low on water. The radiator was full and the overflow was full most of the time the low coolant light came on If I were you I wouldn't ignore the fact that a low coolant light is coming on. My water pump bearing went completly out.
Better safe than sorry right?!?
Old Jul 29, 2005 | 12:27 PM
Z28barnett's Avatar
I tried this and it didn't work for me. I would suggest a new sensor.
There are two kinds with different connectors, shoebox site decribes them.
Old Jul 29, 2005 | 03:18 PM
lamb110's Avatar
see i was thinking that i was loosing coolant because of a blown head gasket (i'm always thinking worst case) but it has NEVER over heated. its gotten hot like a hair over 210 degrees, but that was when i was stuck in traffic on a 95+ degree day. I have a 160 degree thermo, and the fans kick on ealier thanks to Ion's tuning.
I'm going to go get a new sensor tomarrow and change it, hoprefully that works out, if not then i'll start to get scared.
Old Jul 29, 2005 | 03:31 PM
Ultra_Dog's Avatar
STOP! Do not disconnect your warning light. It is telling you that you need to do something about your coolant.
I had the same problem.. Check the overflow hose for flow. Mine was clogged and I was losing coolant. It goes between the radiator cap to the reservoir. It can get clogged with goober/calcium. I had to sandblast it from the inside. You also may have some air in the system. Have you opened the purge valve?
Old Jul 29, 2005 | 04:06 PM
97formulakid's Avatar
be carefull when you take out the sensor because antifreeze will come out. my light lit up all the time but that was after i changed the water pump. it finally quit doing that. the level was always fine so i wouldnt worry about it unless you car starts to heat up really bad.
calaban
May 18, 2020 06:43 PM
silvermansteve
Mar 4, 2015 05:02 PM
Jan 23, 2015 01:13 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Dec 4, 2014 11:56 AM
