Low coolant light after WOT...
Old Apr 10, 2007 | 12:24 AM
Whitey13's Avatar
Ok, so some douche in a honda cuts me off after he passes me at probably 80 mph or so. Camaro's don't follow other cars, especially ricers, so I passed him doing about 120. Shortly after my low coolant light comes on. Car didn't overheat the rest of the way home which was about 4 miles. No smell of coolant. Didn't have time to check under the hood either. What do you all think? Thanks in advance.
Old Apr 10, 2007 | 01:14 AM
TAKASHI's Avatar
damn i got that same problem too. i check everything and i have colant but that stupid light dosent go away
Old Apr 10, 2007 | 01:17 AM
lt11997's Avatar
Check the sensor on the radiator, these are coomon to go bad.
Old Apr 10, 2007 | 02:43 AM
Ratlor's Avatar
They do go bad often. Both mine and my friend's lt1s have gone bad. Easiest fix: Unplug the wire from the sensor, it's on the side of the radiator by the battery. You can buy a new sensor and put it in as well, it will cost around $30, probably less. Just make sure you drain the radiator first.
Old Apr 10, 2007 | 03:44 AM
6SpdLT1Z's Avatar
Old Apr 10, 2007 | 07:03 AM
afr lt1's Avatar
I have same prob. Full of coolant and the light stays on. I was thinking that it had to be turned off with a scanner or something.
Old Apr 10, 2007 | 01:42 PM
2000GTP's Avatar
Probably just a bad sensor or connection.
Old Apr 10, 2007 | 10:08 PM
joshuas93lt-1's Avatar
same problem here
i have a 93 lt-1 and bad sensor these cars are well known for this, replace sensor if it's a 94 and up 93's are obselete. second choice disconnect your sensor
Old Apr 10, 2007 | 10:16 PM
It is not connected to the computer, so a scanner it not going to reset it.
Old Apr 10, 2007 | 10:19 PM
Whitey13's Avatar
Thanks for the help. Sensor is indeed shot; I'm going to replace it.
calaban
May 18, 2020 06:43 PM
silvermansteve
Mar 4, 2015 05:02 PM
MattFick
Feb 15, 2015 10:16 PM
Jan 23, 2015 01:13 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
